The heads flow 285 cfm at .600 lift on intake and 193 cfm at .600 lift on exhaust.
I gapped the plugs at .050. Is this the reason I'm getting misfires (engine light code P0300)? If this is the wrong gap for my set-up, if .050 is wrong, which gap should I use?
The misfire is from the slight lope the cam has. The HOT Cam, which is small than your cam causes this as well.
You can either raise the threshold rpm at which the PCM looks for misfire, you can disable misfire, or sometimes raising the idle speed to ~900rpm will take care of it. Regardless of method, the PCM needs to be reflashed.
engines operating at low speed/low load will typ experience fewer misses with 'wider' spark plug gaps (early daze of emissions controls had some gm engines at .060'' gap to meet idle quality)...high rpm/high load will see better power/ lower emissions with 'tighter' spark gaps.
fwiw... back/day we ran a rail drag car/hilborne injected 302 chevy with a vertex mag, vertex recommended plug gap was .020''... in 'the fog of battle', we ran a set of plugs 'out of the box' at .035'' and lost a tenth, next pass closed same plugs to .020 and got the tenth back.
