martybelairman
Old Jun 29, 2009 | 11:47 PM
martybelairman's Avatar
martybelairman
4th Gear
Default martybelairman
Greetings to eveyone. Wanted too say hello , I am glad too be onboard.
I also have a ? and hope you don,t find this redundant. So here goes.
I have a 90 vette with problem with fuel. I have finally located 5 relays under passenger side dash, but the 64k$? is which one is the
fuel pump relay? And while we are in there , what are the other 4 relays for? Thanks for your time and assistance... Marty
Old Jun 30, 2009 | 08:02 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Welcome aboard, from what I recall, it's the middle one of the 5.
Hopefully someone with a 90, can chime in and confirm.
Old Jun 30, 2009 | 08:31 AM
martybelairman
4th Gear
I sure appreciate thet help. will try it real soon. Thanks Marty
Old Jun 30, 2009 | 08:47 AM
floridamale's Avatar
floridamale
Check the part # on the relays quite offten they are the same # just handle a different system. Welcom aboard
Also with the # you should be able to call Chevy and they will tell you what it is listed for
Old Jun 30, 2009 | 09:11 AM
martybelairman
4th Gear
Thanks for your response. I'll keep searching, and then draw a schematic when the search is over. Thanks again Marty
To martybelairman
