front end clunk
Jul 4, 2009 | 05:51 PM
front end clunk
i have a 94.when iam stopped then turn left fast i hear a clunk in the front end.any help would be very appreciated
thanks
Jul 4, 2009 | 07:32 PM
Check the brake pads/calipers as they may have worn pins and allowing for too much slop.
Jul 4, 2009 | 09:13 PM
Check your front sway bar bushings. If they are metal to metal, it will produce a pronounced clunk.
Jul 5, 2009 | 09:34 AM
St. Jude Donor '10-'11-'12-'13
Quote:
Originally Posted by
engle1147
Can you buy just the caliper pins or do you need to buy the whole caliper..
Jul 5, 2009 | 10:18 AM
ks5shooter
I know NAPA sells the pins by themseleves.
Jul 5, 2009 | 11:53 AM
engle1147
thanks
Jul 5, 2009 | 12:09 PM
IMO check your bushings, ball joints, tie rods
Jul 5, 2009 | 02:43 PM
This may actually be my problem as well. Thanks for posting!
Jul 5, 2009 | 06:47 PM
Frizlefrak
I had the same problem and it was the sway bar. I know it may be something else but start with the simple things and go from there. Good luck
Jul 5, 2009 | 10:21 PM
pologreen1
New lower ball joints fixed a similar problem for me. (After checking the condition of the sway bar links & tie rod ends.)
