Hood opening tool
Old Jul 5, 2009 | 02:51 PM
Greg Johnson's Avatar
Greg Johnson
Default Hood opening tool
Dear Friends,
I can't get the hood open. Cable does not release on driver's side. I have the hood opening tool and have used it before successfully, but not luck this time.
Does anybody have a photo of the cable attachment to the release under the hood? I can't remember where the hole is! This is not an uncommon problem when you are over age 60 like me!
Gregor
Old Jul 5, 2009 | 03:35 PM
-=Tom=-'s Avatar
-=Tom=-
Old Jul 6, 2009 | 12:28 PM
Love The Vette's Avatar
Love The Vette
Install what he and I have and you will never need that hard to use tool again.
Old Jul 6, 2009 | 07:54 PM
Greg Johnson
Thanks, Tom!
Old Jul 6, 2009 | 07:55 PM
Greg Johnson
Love the Vette,
Thanks. I have been intending to do that.
Old Jul 6, 2009 | 08:09 PM
Greg Johnson
I got it right away! Thanks again, Tom. I am off to get some cable and crimpers!
Old Jul 6, 2009 | 11:00 PM
-=Tom=-'s Avatar
-=Tom=-
I'm glad that helped.
Old Jul 7, 2009 | 12:51 AM
ZRWON's Avatar
ZRWON
I AGREE. EVEN IF IT IS ONLY THE CHEAP & QUICK VERSION...
Old Jul 7, 2009 | 01:34 AM
samsonb's Avatar
samsonb
Originally Posted by -=Tom=-
I plan on doing that after I reseal the hood seal. I may pull it off to clean up all the gunk before I seal it.
Anyways, how do you crimp the Ferrel I believe it is called? I've got a regular butt connector crimper. Do you put the wire in both slots, then crimp?
Old Jul 7, 2009 | 07:40 AM
-=Tom=-'s Avatar
-=Tom=-
You got it.
Old Jul 7, 2009 | 08:24 AM
Greg Johnson
I bought 1/16 cable---two lengths of 18" and four little fittings that squeeze the cables for the loops. Got 'er done!
Thanks again!
Old Jul 7, 2009 | 08:28 AM
samsonb's Avatar
samsonb
You got it.
Do you crimp it at the sides of the wires, or on top? I'm guessing on top.
And since we are in the general area. What do you guys use to seal the crack inbetween the hood seal and cowl? I need to do that first as I'm thinking of pulling the hood seal, clean up the old goop, bolt it back on and reseal it. Or I may just clean up what I can, leave the hood seal in place, and reseal it.
Old Jul 8, 2009 | 01:22 PM
Greg Johnson
Josh,
You can use a block and a hammer and chisel or a crimper. If you are gentle, you can use your wiring pliers, but be careful not to cut through the ferrel.
Gregors
Old Jul 8, 2009 | 01:37 PM
samsonb's Avatar
samsonb
Originally Posted by Greg Johnson
Josh,
Gregors
Thanks. Do you by any chance know of what to use to reseal the seam inbetween the hood seal and cowl? I get water leaking into the engine bay, so I need to reseal the hood seal. But I only want to do it once.
I had thought about pulling it and cleaning up all the old crap, but I don't know if I want to do that as I've got alot of other stuff going on. I may just wipe it down real good, and run a bead of sealant.
Most of what they have at Autozone is gasket making stuff. I did see a tube of Permatex adhesive sealant. And then there is the Permatex Right Stuff that gets good reviews, but I think that is used to make gaskets with instead of sealing up a seam to make it water proof.
Old Jul 8, 2009 | 01:53 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Dear Friends,
Gregor
You have CRS?
Join the club!
CAJUN C4's Avatar
CAJUN C4
Suggestion: Looks like your latches etc. need grease pretty bad.This will multiply pressure required to open the hood and put exessive force requirements on the release cables. IMO.
Old Jul 8, 2009 | 02:41 PM
chatham's Avatar
chatham
i have worked with cable for over 30 years so a word of advise....
in the industry the cable sleeves are typically called nicopress fittings. generic like klenex for tissue. to ensure that you properly seat the fitting you need to use the correct tool. these tools are properly sized for different sized fittings to ensure proper, secure and complete compression of the fitting around the cable. while the other methods can work, you do run the risk of over or under compressing the fitting which in time can cause the cable to break or slip out of the fitting when you go to pull it after. so be sure to test it vigurously. sitting there under the hood getting wet or crimed or whatever else happens for months or even years might surprise you when you go to pull that cable when you need it most. the cost of a compression tool at home depot isnt that much.
To Hood opening tool
