Remove seat back
Old Jul 6, 2009 | 07:57 AM
ddahlgren's Avatar
ddahlgren
Default Remove seat back
I have read and reread the fsm and for the life of me can not fid the clips i am supposed to unhook to remove the seatback cushion. I am trying to get some play out of the seats the back moves about an inch or so front to back. I have the seat out changing the power track so seems like the perfect time but don't want to spend forever on it either..
Dave
Old Jul 6, 2009 | 09:15 AM
93v's Avatar
93v
If you put your hands in behind the cushion about in the middle and pull sideways in and then out it should pull out,takes a little pressure.Do a search i think there's pics of it somewhere on the forum,once you see the pics you'll see how easy it is
Old Jul 6, 2009 | 09:24 AM
WW7's Avatar
WW7
There are metel clips that the wire on the back of the seat snap into. I use a large screwdriver to push the wire out of the clip to release the seat back. Not hard just need to be aggressive...WW
Old Jul 6, 2009 | 12:05 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Dave
Maybe these photos will help you:
If you pull the cushion away from the seat back, you can then slip your hand in to push the heavy retainer wire out of the clip. Reverse the process to re-install into the clips.
FYI, I had the same play you are describing. What I did was build up some J-B weld on the metal seat-bottom frame where it contacts the seat-back frame. So far it's holding.
Old Jul 6, 2009 | 12:44 PM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
I ground a crescent shape into the blade of an old large flathead screwdriver. It made removing and installing the seat cushions a snap. Also didn't have to worry about the screwdriver slipping off of the wire.
Old Jul 24, 2021 | 09:54 AM
christophe33's Avatar
christophe33
Hello everyone, I am changing my c4 92 seat but I cannot staple the foam on the backrest, there are 4 staples but what should I do when the foam is new?
Thanks for your help
Christophe
To Remove seat back
