any easy kill switch?
Old Jul 8, 2009 | 05:32 AM
slim jim 2's Avatar
slim jim 2
whats your mom look like if she is hot she can drive mine anytime
Old Jul 8, 2009 | 07:29 AM
TA's Avatar
TA
Originally Posted by CedoNulli
If the Vette is in his name and he is making the payments then screw that. I would not want my mother taking my car either.
If he called the cops, even if it was his mother. Its theft. He could get her in trouble.
Old Jul 8, 2009 | 07:36 AM
Willymo's Avatar
Willymo
jeffp1167's Avatar
jeffp1167
You guys are putting way too much thought into a simple solution .... Simply do this have a VATS key that is of a different resistance then your correct key and let her have access to those keys only. end of problem.
Old Jul 8, 2009 | 10:49 AM
MK 82's Avatar
MK 82
Grow a set and take the key from her.
Old Jul 8, 2009 | 10:55 AM
ejscarfo's Avatar
ejscarfo
This reminds me of when I lived at home and my mom would use my new Mustang. I didn't really mind because at least she would fill the tank. She even broke the turn signal switch and took it to the dealer to get fixed, she could of left that to me.
Anyway, a quick snip of the neutral safety switch would do fine, as well as pulling the fuel pump fuse. The only problem I see with pulling the fuse is the car will still crank and she may drain the battery while trying to start the car. With the neutral safety switch, its dead, you turn the key and nothing. If I remember right, it was a purple wire, but the last time I installed a kill switch it was on my 79 Malibu.
Old Jul 8, 2009 | 11:26 AM
Klondike's Avatar
Klondike
Neutral safety or clutch switch seem to be the best ideas besides keeping the keys away from her. Disconnecting the battery just makes the computer have to 'relearn' every time it gets reconnected. That hurts mileage and drive-ability while it gets reacquainted with all the sensors. If it just won't crank when the key is turned, nothing is damaged. The starter doesn't get fried from continuous cranking and the battery doesn't get dead either. If the key turns and....nothing happens, she'll not want to spend any money on something that might be broke and she'll leave it alone.
Old Jul 8, 2009 | 11:43 AM
Bad Karma's Avatar
Bad Karma
I had one on a previous car, fuel pump kill switch. Wire it in so the fuel pump gets no power, no fuel, no start. Mine was a keyed switch, but you could just hide the switch somewhere.
My Mom would never have taken my car and not put gas in it. Love my family!
Old Jul 8, 2009 | 07:29 PM
Eakster's Avatar
Eakster
Originally Posted by ejscarfo
as well as pulling the fuel pump fuse. The only problem I see with pulling the fuse is the car will still crank and she may drain the battery while trying to start the car. .
This is my emergency theft deterrent.
Don't they sell anti-theft devices near you? steering wheel lock, trans lever lock, etc?
oh and teenager with a vette? No sympathy here..
Old Jul 8, 2009 | 07:50 PM
Sweet 90's Avatar
Sweet 90
Call "Q" and have this installed, problem solved
Jim
Old Jul 8, 2009 | 10:31 PM
RedLS1GTO's Avatar
RedLS1GTO
Did mom pay for the car? If not, did you save enough to buy it on your own by living in her house and not having any other financial responsibility?
If the answer to either of these is YES then you don't have much to complain about.
If the answer is NO, then I have a crazy idea. Grow up and ask her not to drive it.
Putting a kill switch in a car to keep mommy from driving it is the most immature and moronic thing I have heard in a long time.
Old Jul 8, 2009 | 10:34 PM
pologreen1's Avatar
pologreen1
take her car to the race track on the weekend
smoke show contest too
