Trans fluid
Old Jul 10, 2009 | 09:29 PM
lilredvetteL98's Avatar
lilredvetteL98
6th Gear
Default Trans fluid
Want to change auto trans fluid. The manual says to use Dextron ll. The auto parts store says to use Dextron Vl. Can anyone clarify this?
Would appreciate any help.
Old Jul 10, 2009 | 09:55 PM
Aardwolf's Avatar
Aardwolf
Dexron-VI
DEXRON(R)-VI was introduced in 2005. It was designed to replace all prior specifications, and is therefore backwards-compatible with applications calling for DEXRON(R) of any type.
Old Jul 10, 2009 | 10:00 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Never heard of the Dexron you described. When I changed the fluid in my '93, I'm almost certain I used Dexron III fluid with no problems.
Old Jul 16, 2009 | 02:57 PM
tc sr's Avatar
tc sr
I just changed my fluid on my 95 and I used dexron VI castrol synthetic.
Old Jul 16, 2009 | 04:03 PM
CAJUN C4's Avatar
CAJUN C4
Old Jul 16, 2009 | 06:11 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Did you evacuate all of the fluid or just drop the pan? I'm guessing that it's not preferred to mix synthetic with older fluid. Does anyone know if doing this would actually create problems?
To Trans fluid
