Hood cable retainer ????
Old Jul 12, 2009 | 11:42 AM
Calderone's Avatar
Calderone
Default Hood cable retainer ????
Hi,i bought new hood cables and retainer
im about to install them,but ..where does the retainer go ???
its a very small piece
Old Jul 12, 2009 | 05:09 PM
jimg's'93's Avatar
jimg's'93
Hey Calder. That clip mounts on the end of the arm/lever that moves to free the hood latch bolt. The very terminating end of the release cable is held to this lever by that clip.
Hope that helps!
Old Jul 12, 2009 | 08:26 PM
Calderone's Avatar
Calderone
thanks Jim ! i discovered that today
wow...it was a real pain to install this cable
i can't make it work ok,everything is working ok without the handle
but the cables seems too short for the handle.....i spent a lot of time
trying to make them right !
Old Jul 12, 2009 | 08:48 PM
jimg's'93's Avatar
jimg's'93
Make sure you're attaching the cable to the handle first, then complete the connection at the retainer clip. Then you can use the cable adjuster to tighten it all back up.
Old Jul 12, 2009 | 08:56 PM
Calderone's Avatar
Calderone
Thanks for the tip,yes i did that
and i guess i connected the cables in a wrong way to the handle ...
they pushed the cables instead of pulling them...
any pictures of the handle and cables installed ?
thanks
Old Jul 14, 2009 | 11:53 AM
jimg's'93's Avatar
jimg's'93
Wish I could help you with pics. My camera has the old SD card format and my card finally failed on me and nobody carries them locally.
If I can get a new card soon, I'll have pics.
Old Dec 8, 2010 | 10:08 AM
Calderone's Avatar
Calderone
What's the correct orientation of this retainers ? they have two small horns but im not sure if those goes pointing front or rear, thanks !
Which one would be facing front ?
Old Dec 8, 2010 | 11:31 AM
jon0108's Avatar
jon0108
I dont want to hijack but where did you get the kit from? In the spring Im going to change my cables, but the kit I looked at doesnt include the retaining clips like you have pictured. I actually need the clips now, they kind of split. Im driving on borrowed time, but the cars away for the winter.
Old Dec 8, 2010 | 11:44 AM
Calderone's Avatar
Calderone
watch out Jon because if they do , you'll have a bad headache, first of all
Buy emergency cables, then you can breath safe and you can buy everything at slow pace. Its not a complete kit.
I bought them at Midamerica, i bought the cables , which are installed
then i bought the retainers, which goes for $7 each
Everything is here :
http://www.mamotorworks.com/corvette?frame=1.946
But PLEEEAHHSE ...Buy this first
http://www.mamotorworks.com/corvette?frame=1.8064
Old Dec 8, 2010 | 12:11 PM
jon0108's Avatar
jon0108
Thanks. Just went to my garage to see how they are installed on my 86. The 2 "small horns" go facing the front of the car. There is actually a place for the points to go into.
Old Dec 8, 2010 | 12:19 PM
jon0108's Avatar
jon0108
Im going to get the kit from a forum vendor, corvette recycling, which includes new springs and handle also
http://www.corvetterecycling.com/product_p/10273994.htm
Doesnt come with the cable retainers though.
Old Dec 8, 2010 | 12:21 PM
Calderone's Avatar
Calderone
Thanks , yes you refreshened my memory, the latch has two small cutouts where the horns go locked
Oh cool ,but which springs ?
Old Dec 8, 2010 | 12:25 PM
jon0108's Avatar
jon0108
That open end area you see here,(the top of the retainer), should face the windshield
Old Dec 8, 2010 | 12:27 PM
jon0108's Avatar
jon0108
The springs that attach to the underside of the hood. They are heavy duty and allow the hood to "pop" open when you pull the release handle.
Old Dec 8, 2010 | 12:30 PM
jon0108's Avatar
jon0108
Theres actually a left and a right. If you look closely on the side of the retainer, towards the top, where its folded over itself, there is a small point. Its only on one side and not the other.
Old Dec 8, 2010 | 12:34 PM
Calderone's Avatar
Calderone
Ahhh yes , those are good on mine
Don't think so,i have them right here, both are identical ,they look different on the picture because they are facing different directions
Old Dec 8, 2010 | 12:41 PM
jon0108's Avatar
jon0108
let me go to my garage again and see. Give me a few.
To Hood cable retainer ????
Old Dec 8, 2010 | 12:53 PM
jon0108's Avatar
jon0108
you see, thats what happens when someone is unemployed and has ocd.(Im talking about me) Your absolutely right. They are the same
Old Dec 8, 2010 | 01:24 PM
Calderone's Avatar
Calderone
he he
Old Mar 30, 2013 | 09:33 AM
tonyfauvelle's Avatar
tonyfauvelle
2nd Gear
Default hood cable retainer
Does anyone know where I can get a couple of retainer clips for the hood cables on a c4 that attach to the hood release,as seen in caldones picture on this forum.
thanks
