Headliner repair
Old Jul 13, 2009 | 07:33 AM
kalister1's Avatar
kalister1
Default Headliner repair
My headliner has been droopy for a good long time. So the wife says get some fabric and a can of spray adhesive from the local fabric store and we can fix it. Easy enough to get it out, just pull it out. The padding comes right out, no tools. We clean off the old mess and use the spray adhesive to put on the new fabric, everything looks great.
BUT, The fabric fell off in just a few hours. Has anybody done this? And what did you use to glue it on?
Is there an industrial spray on adhesive I can get? I see Mid-America sells a spray can, but now I am leery of spending $20.00 and getting the same results.
I drive the Vette to work this morning with no headliner and now the cruise does not work, I had no idea they were connected?
Old Jul 13, 2009 | 07:38 AM
runner140*'s Avatar
runner140*
The adhesive you need for the job (headliner) is 3M Adhesive spray. I used about a 1/4 of a can on my headliner using the existing fabric.
Old Jul 13, 2009 | 08:56 AM
kalister1's Avatar
kalister1
Thanks, I'll get me a can.
Old Jul 13, 2009 | 10:16 AM
jhammons01's Avatar
jhammons01
^^Yeah the Headliner and the Cruise are both connected via the Knutson Valve....if you are low on Headlight fluid, they both suffer greatly.....
and that 3M stuff....that stuff is like....well just make sure you spray it in an area where you can lay down some disposable plastic...like what you get at Lowes for painting and then wear rubber gloves....it doesn't come off anything.
My wife got some of the other from Micheals and it is not nearly the animal the 3M stuff is.
I used to use the 3M on pool table felt you spray it and stick it......it is done.
Old Jul 13, 2009 | 12:34 PM
Love The Vette's Avatar
Love The Vette
Old Jul 13, 2009 | 05:27 PM
eagleye's Avatar
eagleye
I used the 3M stuff that I picked up in Lowe's. I went to a fabric store and they actually had material for headliners. I got a piece of leatherlike stuff that had a backing on it. Went outside with the top and sprayed about a 1/4 can on and let it sit a few minutes before I put the fabric down. I rolled it on with a wall paper seem roller and let it sit for 2 days before I trimmed the edges. It covered some of the imperfections in the padding on the roof and it looks great too. No more hanging headliner!
Old Jul 13, 2009 | 07:22 PM
kalister1's Avatar
kalister1
Thanks for all the help. I will call my local stealership for a new Knutson Valve.
I bought a can of 3M Hi-Strength 90 adhesive.
Old Jul 13, 2009 | 07:29 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
3M 8088 glue is what you need
Old Jul 15, 2009 | 03:02 AM
powerpigz-51's Avatar
powerpigz-51
You will have better results if you spray both surfaces (cloth and top). Use sparingly or the adhesive will soak through.
Old Jul 15, 2009 | 10:54 AM
JonnyAngle's Avatar
JonnyAngle
I ripped out the headliner and foam, sanded it, and painted it. It sure seemed to open up some more headroom.
Old Jul 15, 2009 | 12:01 PM
DVNCI's Avatar
DVNCI
Sounds like you are well on your way to fixing it but you might be surprised how cheaply a local interior shop might do it.
I had mine done and he put new padding in and it looks much higher-end now - and was pretty cheap.
To Headliner repair
