ABS Question
Old Jul 14, 2009 | 05:55 PM
mikey531's Avatar
mikey531
Default ABS Question
Hi
Should I hear my ABS cycle or something when I start my 1994 Corvette? I am not getting any light or codes but how do I know if it is working? I did put my hand on it when I turned on the switch and could feel it click hear a faint whir.
Old Jul 14, 2009 | 07:48 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
After engine start-up, when you reach 3mph the abs pump cycles and the indicator on the dic lights for a few seconds.
Old Jul 14, 2009 | 08:00 PM
mikey531's Avatar
mikey531
The problem is my corvette isn't registered or insured so I can't try that. As I said I can hear it whir and feel a click like a solenoid and I don't get any codes so should I assume everything is ok?
Old Jul 14, 2009 | 08:47 PM
Goldcylon's Avatar
Goldcylon
Normal ABS noise self test. It wont show any codes the DIC (Drivers Information Center) will flash ABS for a split second.
Old Jul 14, 2009 | 08:50 PM
mikey531's Avatar
mikey531
so Goldcylon your opinion is everything is normal?
Old Jul 14, 2009 | 08:52 PM
Goldcylon's Avatar
Goldcylon
Originally Posted by mikey531
so goldcylon your opinion is everything is normal?
100% If you head into work At 4Am like I do the flash is more evident after backing down the driveway and moving forward
To ABS Question
