Widest Tire !!!!
Old Jul 22, 2009 | 11:06 PM
ol school's Avatar
ol school
Default Widest Tire !!!!
I lost some info i had saved.. Not trying to start a long drawn out post.
Need to know THE WIDEST TIRE I CAN USE IN THE REAR OF MY 96
USING STOCK 17X9 WHEEL (i believe thats stock size) .. I have to purchase a new tire ,figured id buy a pr. for the rear only , and want to put the absolute widest I can , car is not lowered in case it makes a differance..
Thanks ..
Old Jul 22, 2009 | 11:19 PM
StealthLT4's Avatar
StealthLT4
Stock is 17x9.5", and 285/40-17 is the widest that's designed to fit on that rim. You won't gain anything from using a wider tire than that, aside from a ballooned look and an emptied wallet. The actual contact patch will be no larger due to the altered geometry, and the sidewall might also overheat because of how much it is bent.
Old Jul 22, 2009 | 11:25 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Originally Posted by StealthLT4
285/40-17
Old Jul 22, 2009 | 11:30 PM
ol school's Avatar
ol school
Old Jul 23, 2009 | 08:42 AM
TA's Avatar
TA
You could squeeze a 315 on a 9.5" rim, but as others have mentioned the sidewall will balloon and your contact patch probably won't be any wider anyway. I'll add though that Sumitomo 315s are verrrry narrow (compared to other brand 315s) and actually fit on a 9.5" rim quite well.
Old Jul 23, 2009 | 09:51 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I've seen it done, they go on the rim, but it's not the best fit which is why I bought the wheels I did.
Old Jul 23, 2009 | 06:40 PM
mnstrlt1's Avatar
mnstrlt1
not necessarily wider, but gives you a larger list of tires to choose from is a 275 series.
Old Jul 23, 2009 | 06:49 PM
tequilaboy's Avatar
tequilaboy
If a drag radial is under consideration, check out the Mickey Thompson ET Street Radial II in 295/45R17.
Supposedly it can fit on a 9" wheel.
Old Jul 23, 2009 | 11:46 PM
ol school's Avatar
ol school
Ill look into it , Thanks
To Widest Tire !!!!
