still having problem's
Old Jul 24, 2009 | 05:26 PM
ricky's c4's Avatar
ricky's c4
Default still having problem's
93 lt1, start's fine after sitting all night, won't start after it has been warmed up. fuel pressure 42 lbs and hold's it. changed ignition module with the one on my car and does the same thing. maybe coil? that or ecm. not much left. do opti's do this when going bad?
Old Jul 24, 2009 | 06:20 PM
jabez's Avatar
jabez
I had a defective ECM once. Car would start fine in the morning or when I parked under shade. But if I tried to start car after a long drive or when engine was hot it wouldn't go. It just cranked. I switched out the ECM the problem was gone.
I would test it out before searching for a new ECM. See if cooler engine would solve your problem.
Old Jul 24, 2009 | 06:50 PM
ricky's c4's Avatar
ricky's c4
as long as the motor is cooled down fully it will start, and run fine, no issue's. looking for a compatible computer to borrow to see if that is it. i'm working on this car for a friend, his is a 93, my computer is totally different.
To still having problem's
