Paint code for an 84 C4???
Old Jul 28, 2009 | 08:58 PM
dchoran's Avatar
dchoran
From: Appleton, Wisconsin Boston originally - North End
Default Paint code for an 84 C4???
Anybody know where this is????????????????
dave H. Appleton, WI dchoran@athenet.net
Old Jul 28, 2009 | 09:00 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
On your data plate
Here is a website that explains it
http://www.rogerscorvette.com/specs/84.htm
Old Jul 28, 2009 | 09:12 PM
RetiredSFC 97
heres another site that is somewhat different but you should be able to tell from the Vin which is correct
http://corvettelink.com/corvette_paint.asp?Color=White
Old Jul 28, 2009 | 09:19 PM
dchoran's Avatar
dchoran
Thanks for the links - but they all say where it might be not where it actually is.
Anybody know for sure on an '84???
Even the guy at O'Reilly could not find it after 10 minutes of looking around.
THANKS
Old Jul 29, 2009 | 07:29 PM
RedVette84's Avatar
RedVette84
Wouldn't it be on your build sheet?
Old Jul 29, 2009 | 07:40 PM
c4cruiser's Avatar
c4cruiser
There should be a Service Parts Identification sticker either on the underside of the console lid or under the lid of the passenger side rear storage compartment.
If this sticker is gone, you can look here Scroll down to the 1984 chart and find your factory car color. The left column has the OEM RPO code and the far right column has the WA code. Both of these codes would show up on the sticker. The 033 would be in the list of the 3-digit RPO codes, and the WA number would be on the last line at the bottom of the sticker.
Some paint codes will have a "U" or "L" after the paint RPO code. That donates Upper or Lower as some early 80's C4's had two tone paint. The U or L would still show up even though the car only has a single color.
If you are looking for something like Dupli-Color touch up paint typically sold by parts stores, use the WA code. As an example if your car is Bright Red, the OEM RPO code is 33. The WA code is 8551.
The other codes shown are used by various auto paint manufacturers to mix up the correct color when a car is being painted to match the factory code.
To Paint code for an 84 C4???
