Sunvisor removal/replacement-86
Old Aug 6, 2009 | 07:39 PM
Elrick's Avatar
Elrick
Default Sunvisor removal/replacement-86
How do you get the sunvisor off of the rod that it's on? Do you slide it off, I can't tell if there is a retaining clip on the end. Can you change it out without removing the rod from the top of the windshield. I got new ones but they are just the visor part not the hanging bracket/rod piece. I have to use the old one, which hopefully I can
Old Aug 6, 2009 | 09:48 PM
Elrick's Avatar
Elrick
I got it, just slide them off with a bit of pressure. Just so sick of breaking little plastic tabs everywhere I was scared to push too hard
Old Aug 7, 2009 | 12:01 AM
GKK's Avatar
GKK
Thanks, for the tip.
Also, did your visors have the lighted vanity mirrors which had to be disconnected?
Old Aug 7, 2009 | 05:22 PM
Elrick's Avatar
Elrick
yes, you have to unscrew the plastic trim plate on top of windshield,where the top bolts on, once that is off, take out the first few screws on the inside windshield trim and you can pry it back just enough to wiggle out the vanity mirror light. Just be careful as it would suck to crack plastic trim
Old Aug 7, 2009 | 05:54 PM
GKK's Avatar
GKK
Thank you.
To Sunvisor removal/replacement-86
