Symptoms of a bad EGR valve?
what kind of symptoms could expect if I had a malfunctioning EGR valve - would it cause a ruff idle problem??, there are no codes
the EGR does not energize unless the you are in a cruise mode. It does not activate when idleing or, when accelerating. the reason for a bad idle (if you have a defective bladder ) the result is a vacuum leak. The vacuum leak would then be causing the rough idle. If you have this problem, Replacing the EGR would solve it. You can test this by pintching, or disconnecting the vacuum source to the EGR. If the problem goes away, That's your problem. If not, you need to look elseware
An EGR valve that won't open when it is supposed to will cause high NOx emissions. An EGR valve that won't close when it is supposed to will cause rough idle and/or engine dies. The most common failures would be carbon buildup keeping it from closing or a leak in the vacuum line or diaphram keeping it from opening.
To check for a cracked diaphram just spray some carb or TB cleaner under the EGR valve, if the idle picks up you have a cracked or leaking diaphram.Also as far as a stuck egr, it depends how far open the egr is stuck,if its stuck wide open the car will surge and stall,if its stuck slightly open it will idle ruff and likely surge at steady cruise speed, if its stuck closed you will have higher temps in the combustion chamber which will very likely cause pinging..If you have a (factory service manual) it tells you how to test the EGR....WW
How do i know if the EGR valve sensor is bad. I installed a new EGR and still have a rough Idle and hard starting. It even has a dead spot now and missing under a load. Any ideas out there?
