Oil cap help
Old Aug 18, 2009 | 10:10 AM
61LS6's Avatar
61LS6
Default Oil cap help
The oil cap on my 1990 only spins and won't come off. Any suggestions?
Old Aug 18, 2009 | 03:35 PM
WW7's Avatar
WW7
What is happening is the click lock on the cap is stripped..Try taking a large pair of adjustable pliers and squeezing real hard while you turn it , this may get it off..If that doesn't work you may have to break the outer ring off, then remove it. Either way your going to need a new cap, will be around $9.00 ....WW
Old Aug 19, 2009 | 10:18 AM
61LS6's Avatar
61LS6
Default oil Cap
Thanks for the hint, it,s off
To Oil cap help
