More power - cheap
Old Aug 22, 2009 | 07:41 PM
Jim Nichols's Avatar
Jim Nichols
Default More power - cheap
For those of you that have an L-98, here a fairly inexpensive way to pick up serveral horsepower and a lot of good sound. I replaced the Y-pipe and the precats with a new pipe and single converter. You can feel the power at low speed and the sound is much improved.
Old Aug 22, 2009 | 08:02 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Maybe but not much. If I was to change the exhaust for performance, I go with headers first. The breathing problem with the L98 is the intake. IMHO
Old Aug 22, 2009 | 09:41 PM
cgl61's Avatar
cgl61
Just did the same thing. Dumped the precats with the Catco system from Jegs or Summit. I don't recall now, I've bought so many items in the last 3 monthc. Single cat now. Stock cleaned up y-pipe and the LT1 black tipped muffler eliminators. The car sounds great now. Revs quicker also. I think the old cats were shot, clogged or whatever they become with age.
Old Aug 22, 2009 | 09:48 PM
Jim Nichols
My deal was less than $300 installed. That was my cheap comment. By the way...I already have cold air ram induction.
Old Aug 22, 2009 | 09:52 PM
Jim Nichols
I also am running 10 inch mufflers with very short pipes into the side exhust. See photos in my CF ID
Old Aug 22, 2009 | 10:18 PM
cv67's Avatar
cv67
St. Jude Donor '05
Think he meant the intake manifold itself being restrictive.
Old Aug 22, 2009 | 10:47 PM
Pwnage1337's Avatar
Pwnage1337
The intake air box isn't restrictive, its the runners/plenum/base.
When i ported my intake manifold base, i thought to myself, who the **** designed this?
at the bottom of the ports, there were little half inch tall walls across the whole port. what the hell is that there for? BLOCKING AIR FLOW.
To More power - cheap
