:it is located in the center of the engine, on the front, under the massive rubber intake from the air cleaner. If you look down under the intake you will see the plug wires that come out of it.
ok so i had a waterhose burst. in the process it spewed all the coolent in every possible place under the hood. how do i clean up the mess?
Okay I'll be the first to ask - which hose was it? I've never had to replace one yet, so I'd like to know which is the first to blow? Mine still all look like new so would like to know which one is the culprit.
Sorry to sound dumb but I just got my 1990 and I want to clean my engine is there anything that I need to worry about? From what I am reading the opti is not in a 1990?
Thanks,
Jeff
it was the upper hose going into the water pump. the hose FINALLY got here. at $30 what a steal!
