Infl rest
Old Sep 2, 2009 | 09:52 AM
traxx1's Avatar
traxx1
Default Infl rest
My dic showed infl and below it it read rest ?? what is this ???
Old Sep 2, 2009 | 09:58 AM
Sweet 90's Avatar
Sweet 90
Airbag sensor(s) error usually. Very common on the MY 1990. If you have a '90 I'll bet your seat belt light is on as well. Can be a royal PIA to fix
Jim
Old Sep 2, 2009 | 10:05 AM
traxx1's Avatar
traxx1
Default Infl
I have a 91 but the seat belt light is not on,
Old Sep 2, 2009 | 10:18 AM
Sweet 90's Avatar
Sweet 90
Check out these forums. As you will see it really is more of a '90 problem
http://forums.corvetteforum.com/sear...rchid=12260587
Maybe the fix is the same
Jim
Old Sep 14, 2009 | 06:35 PM
91GreatWhiteShark's Avatar
91GreatWhiteShark
I have a 91 as well and has the same issue. I have read the DERM module may need to be replaced. I don't know the first thing about replacing it. I have also read that is could need to be reset. Confused, so if anyone has info on this, it would be greatly appreciated!
Old Sep 15, 2009 | 04:35 PM
91GreatWhiteShark
Anyone???
Old Sep 16, 2009 | 09:43 AM
gmboileau's Avatar
gmboileau
This is a common problem with 1990's. The mounting point for the sensors on the frame rail corrode causing a poor ground and the light to trip. There are left and right sensors which could cause this problem. Left (Code 16) right( Code 26).
In addition to this there are a number of other problems each with a code .
To get the codes you have to connect terminal A to K on the ALDL computer connection.
The airbag light will flash a series on long and short pulses indicating the specific Code and problem that tripped the light.
Without the Code to point you in the direction of the fault it's just a guessing game.
To Infl rest
