VAT's problem????
Old Sep 10, 2009 | 11:53 AM
1coolvette's Avatar
1coolvette
4th Gear
Default VAT's problem????
Twice now my 95' has faild to start. Nothing happens when you turn the key. No dash board lights, nothing. I'm assume it's a VAT's problem.
1st time it happened after several attempts it cranked. Radio and all the gauges reset.
2nd time after several un-successful attempts to start. I removed the positive cable from the battery. As soon as reconnected it the security system activated and car started.
Any ideas before I take it to the dealer?
Old Sep 10, 2009 | 01:58 PM
Billy Stargazer's Avatar
Billy Stargazer
More than likely the vats, or you could try a different key if you have one. I bypassed my vats and it was the best thing I ever did. I don't have time to mess with a flawed security system (vats) that has so many quirks.
Old Sep 10, 2009 | 02:18 PM
coco1950's Avatar
coco1950
Hey Billy, How do you bypass the vats. Is it a big job ?
Old Sep 10, 2009 | 02:42 PM
runner140*'s Avatar
runner140*
Bad connection between the negative battery terminal and the negative cable.....clean and tighten.
Old Sep 10, 2009 | 03:03 PM
jimg's'93's Avatar
jimg's'93
When it's a VATS issue, you'll at least have a lit dash.
Old Sep 10, 2009 | 03:22 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Clean, tight connections at battery,starter and block, are a must, and will likely cure your problem.
Old Sep 10, 2009 | 05:48 PM
Allieboy's Avatar
Allieboy
i am experiencing the same problem. i went to the dealer to have my key tested and he said it was fine. he told me there is a little copper wire inside the cylinder that goes bad after all the turning. he said it is not the vats
Old Sep 10, 2009 | 07:25 PM
92LRC's Avatar
92LRC
it's likely not VATS. VATS has a time out feature if it fails you can't start it right away again
Old Sep 10, 2009 | 10:42 PM
jfb's Avatar
jfb
Stay as far away from that dealer as you can get yourself. The ign lock has contacts in it that connect to the key pellet and allows the VATS module to measure the pellet resistance. All of this is part of VATS and if the contacts or the wires out of the contacts stop working, its a VATS problem and VATS will not allow the car to crank and start running.
Old Sep 12, 2009 | 01:29 PM
tdf's Avatar
tdf
St. Jude Donor '11
Well guys I had an intermitent "no start" issue with my 86 C4. I started a couple threads on here and most everyone and the FSMs said "if it was VATS it wouldn't crank", and sent me off looking at other posibilities. So I kept looking for the grimlin for quite a while (months). Finally fed up, I bought the "VATs bypass harness". Simple install. Takes 10 minutes maybe. Mine has started every time ever since the bypass went in. My issue didn't pass the logic test per VATS design, as it always cranked. But it was a VATS issue none the less!
Old Sep 12, 2009 | 06:41 PM
tblt44's Avatar
tblt44
If I buy the vats bypass they sell ,will my alarm still work when the doors are opened?
Old Sep 12, 2009 | 10:58 PM
AGENT 86's Avatar
AGENT 86
It would on my 86, not 100% sure on your year.
Old Sep 13, 2009 | 07:49 PM
92LRC's Avatar
92LRC
works on my 92 and I'm bypassed
To VAT's problem????
