Bleeding Brake tips?
Old Sep 12, 2009 | 11:18 PM
megtom2's Avatar
megtom2
Default Bleeding Brake tips?
Yes, I am here again doing my weekend project of changing out all of the pads and rotors. The rears were frozen on and those calipers bracket bolts were a bi......but the search function worked great to help.
The question I have is on the bleeding I have never done this before but since the fluid was black I wanted to bleed all of them down with new fluid. I have been using a hand pump that seems to suck it out fairly well and I have tightened the bleeder screw while plenty of suction was still at the screw. Is this an ok way to properly bleed the system? Also the pass side screw was a royal pain to loosen and now it seems to leak a little bit. Is that normal or should I replace the screw or put something on the threads to seal it?
Thanks again guys. I'm tired and still have driver's front left for tomorrow.
Old Sep 12, 2009 | 11:31 PM
94z07fx3's Avatar
94z07fx3
That method works well.
If the screw leaks only while you're using the vacuum pump then don't worry about it. If it leaks when you screw it all the way in then it's an easy to find and cheap part at any parts store.
You can improve the operation of the vacuum pump, and in particular the one screw that leaks, by wrapping the threads with teflon tape.
Old Sep 13, 2009 | 06:04 AM
mazdaverx7's Avatar
mazdaverx7
i always bleed in a specific order. i bleed at the following points until i have a firm pedal at each point: RR, LR, RF, LF. starting at the farthest point away from the master cylinder has always worked well for me and has ensured that no air was left in any of the lines.
Old Sep 13, 2009 | 10:11 AM
tblt44's Avatar
tblt44
I just bleen mine yesturday,just to get new fluid in the lines.I tried to do a gravity bleed, that was a joke.I was the only one home,I did the drivers side by using a broom handle to depress the pedel when I loosened the bleeder.I had to wait for my daugter to get home to do the other 3.
I do it the cheap way loose screw while someone depresses the pedal,tighten bleeder before pedal is released,repeat till clean fluid comes thru.
Old Sep 13, 2009 | 11:48 AM
megtom2's Avatar
megtom2
Stupid question but I'll check in a minute but the rear bleeders are hidden with the tires on aren't they?? Or at least nearly impossible to get to?
Old Sep 13, 2009 | 01:40 PM
seijack's Avatar
seijack
This is what I do.....I have the Wife help me....After 17 years she is getting pretty good at it.....she loves pushing the brake pedal down LOL!!!!!
Old Sep 13, 2009 | 04:41 PM
mcnulty95's Avatar
mcnulty95
Get some speed bleeders. Makes bleeding the brakes a one man job.
Old Sep 13, 2009 | 05:06 PM
Frizlefrak's Avatar
Frizlefrak
Just make sure you keep the master cylinder full. And as posted above, do in the order of furthest to closest.
A vacuum pump works well too, just a bit messier. Start by siphoning everything out of the master cylinder and refilling with clean fluid. Then flush all the lines.
Old Sep 13, 2009 | 05:49 PM
Z5287's Avatar
Z5287
87 FSM Bleed R/F R/R L/R L/F
I am doing mine again now,Still pulls to the right
Old Sep 13, 2009 | 06:37 PM
Aurora40's Avatar
Aurora40
I've notice using vacuum that some air will come around the threads of the bleeder valve. So I usually do the bulk of the bleeding that way, then let it gravity bleed a little bit to push out any air around the threads.
Old Sep 13, 2009 | 06:56 PM
Race Prepared's Avatar
Race Prepared
Agreed, but I take a turkey baster and remove the existing fluid from the resevoir, clean out the bottom, and fill with fresh fluid.
Old Sep 13, 2009 | 08:03 PM
pacat's Avatar
pacat
Default Advanced Auto free rental
I used a vacum bleeder that I got from Advanced Auto. Works great for when you don't have a helper. Most auto parts stores have a free tool loaner program. You just have to leave a deposit ($100), when you return the tool you will get your deposit back, well worth it.
Old Sep 13, 2009 | 08:14 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Old Sep 13, 2009 | 08:17 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Old Sep 13, 2009 | 10:40 PM
samsonb's Avatar
samsonb
So, what was wrong with the gravity bleed? I did that a few weeks ago with no problems.
Old Sep 13, 2009 | 10:48 PM
CStewTAMU's Avatar
CStewTAMU
What I would do is get a 3-4 foot long piece of tubing like what comes with bleeder kits. You can get this at Home Depot I think.
Get you a glass jar and put some fresh fluid in it. Hook one one end of the tube to the bleeder screw and the other end in the jar keeping it submerged in the fresh fluid. Then, losen the bleeder screw and pump the brake and keep the MS resevoir full.
Doing this way, you won't get any air sucked back into the system.
Old Sep 14, 2009 | 12:00 AM
samsonb's Avatar
samsonb
Air can get past the threads. That is why the speed bleeders have sealant on the threads. Though, I'd go with the Earl solo bleeders instead.
To Bleeding Brake tips?
Old Sep 14, 2009 | 05:54 AM
mazdaverx7's Avatar
mazdaverx7
this is an excellent point made that was overlooked. no reason to push old scummy fluid through the lines. removing the fluid from the master cylinder's resivours and cleaning them with a dry cloth is a very good idea. a lot of the fluid in there is already contaminated and will contaminate the new fluid if it isn't properly flushed,
Old Sep 14, 2009 | 03:40 PM
samsonb's Avatar
samsonb
How does the dirt and crud get inside the reservoir? I never figured that out since it is sealed. Mine had alot of lint type stuff in the bottom of mine I had to vacuum out. I guess the previous shops didn't clean it out since it had a ton of lint all in the bottom.
Old Sep 14, 2009 | 04:16 PM
mazdaverx7's Avatar
mazdaverx7
a lot of it is rubber particles from the boots on the caliper's that prevent leakage around the piston. often times if a seal is bad,moisure can enter the caliper and rust can form. this is where you will see a lot of contamination. some i can assume is from the rubber lines themselves breaking down internally.
