Carpet Dye Application
Old Sep 16, 2009 | 01:58 PM
psunut95's Avatar
psunut95
Default Carpet Dye Application
I have an 86 which was originally graphite but now has turned seafoam green/blue. The carpet is in good condition and I have found a source for the dye but I am unsure as to the best way to apply the dye. I was told that spraying could lead to overspray and be sloppy. I was also told to use a paint brush, but I am afraid it will soak in and apply unevenly.
What is the best way to do this? Thanks for your help.
Old Sep 16, 2009 | 04:21 PM
65747785's Avatar
65747785
Spaying is best. Mask things off you don't want overspray on. Use tape, paper, tinfoil whatever it takes.
You can do a nice job with spraying. Just don't load the spray (paint) on too heavy. You don't want to turn the carpet into a hard surface. When it dries, brush it to stand up the fibers again, then spray another light coat on. Just take you time and you'll have a good looking carpet again.
Old Sep 17, 2009 | 07:22 AM
psunut95's Avatar
psunut95
Great advise, thanks. Can you recommend where to buy a sprayer and what kind? Electric? Battery? Air? I do not want to spend a lot of money but want something that will do a nice job.
Old Sep 17, 2009 | 07:38 AM
megtom2's Avatar
megtom2
Probably should have tried some cheap rit dye first. I used it to dye my 89 formula's gray carpet back to the black it was supposed to be. Worked great and I didn't have to worry about it hardening. I think I was out $5 including the cost of the plastic spray bottle.
Old Sep 17, 2009 | 09:44 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I used a couple of cans of spray on dye, on my graphite 86. Spray on and brush it in, done.
I took out the back pieces to spray, but I did the front with masking tape and paper. Holding up just fine, after a few years.
I'll see if I can find the can to get a name.
Old Sep 17, 2009 | 09:53 AM
AGENT 86's Avatar
AGENT 86
Found a can, it's Burford's.
http://www.autoprodetailproducts.com/page/319812213
Old Sep 17, 2009 | 10:23 AM
65747785's Avatar
65747785
For the past 30 some years with different cars I found just good old spray paint in a can does the same job as spray can dye. Spray dye is hard to find and expensive. Mid America and the like has it, but again it's expensive $8 to $10 a can. Go to any local store, Home Depot, K mart or Wall Fart and get the best match.
When we bought our 2002 TrailBlazer for my wife the owner before had a misshap with bleach. Somehow it opened in the cargo area and beached a basketball size spot in the gray carpet. A spray can of gray primer fixed it right up and you can't tell it was ever sprayed with primer.
Old Sep 17, 2009 | 09:29 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
My `87 had the graphite interior & it atarted to look like crap, but was still in good shape. I just sprayed it with black Plastikote interior dye that I got at Pep Boys for like $7 a can. Looks great & should last until I can save the bucks for replacement carpet.
Old Sep 18, 2009 | 01:18 AM
c4sailor's Avatar
c4sailor
SEM Color Coat www.semproducts.com call them to locate a source near you.
Old Sep 18, 2009 | 01:31 AM
Aerovette's Avatar
Aerovette
I have used spray paint too. The carpet is basically plastic and the paint sticks well. Light light coats and brush ( I used an old hairbrush) after it has dried betwen coats.
Old Sep 18, 2009 | 07:11 AM
psunut95's Avatar
psunut95
Thanks, there sounds like there is hope.
Old Sep 18, 2009 | 07:12 AM
psunut95's Avatar
psunut95
Sounds like this is the consensus with good results. I wil give it a try.
Old Sep 18, 2009 | 02:48 PM
65747785's Avatar
65747785
The best part about it, a can of cheap spray paint only costs a buck. You might find it looks great and no need to buy new carpet. I"ve never had anyone bend over and feel my carpet in my bule/blue 85.
To Carpet Dye Application
