why would my alt. do this ?
it some how decided to eat its pulley / fan combo
and just realley grind that thing out.
so -
the alternator spins freely. actually it spins alot easier than I thought it would - so the only reason I could think of that would cause this would be maby just the pulley was bad from the start , or it was mounted on the alt . improperly.
this sucks. ive heard that pulleys for a 84 vette are verry small diam. to try and speed up the alt to make more power. is this true ?
also will I have a hard time tracking down the correct alt for my car with a correct pulley attached ?
http://www.autozone.com/autozone/cat...&parentId=64-0
-Loosenut-
If you have the non threaded ear (pic looks like it)
Rockauto
REMY Part # 20107 {Reman}
with Unthreaded Adjusting Ear; 108 Amps
* Non-stock item--shipping delayed up to 2 business days
$77.79
Threaded ear:
REMY Part # 20211 {Reman}
with Threaded Adjusting Ear; 108 Amps
$97.99
both plus cores.
I would avoid the Autozone/Advance Auto/ Kragens alts like the plague.
I ended up going to a bennette autto supply store in search of a new alt.
to wich they only had 108 amp models avalable - and proceded to tell me that thats all they were equiped with from the factory since thats what parts they have in the computer for them. - when the parts guy brought it out it had a v belt pulley on it. realley - a v belt ?
for a 84 corvette ? - I bet there is not a c4 in existance on earth with a v belt system on it.
luckly I was able to find a parts store down the road a bit with a box of random pulleys in it and found a match to my alt, and a slightly smaller one too - got it mounted up properly.
suprisingly - the same alternator is still in the car now and it works better than before.
probly because the pulley I put on is verry slightly smaller in diamater, wich will spin the alt a little faster at idle for more output at 700 rpm.
I wonder how long this old dirty alt will keep working before needing a rebuild - wich I also got a # to a local guy who is suposed to be good at rebuilding them - just incase my alt was fried somehow. Daily driving a 84 is wearing out the welcome fast.
I ended up going to a bennette auto supply store in search of a new alt
to witch they only had 108 amp models avaliable - and proceeded to tell me that that's all they were equipted with from the factory since thats what parts they have in the computer for them. - when the parts guy brought it out it had a v belt pulley on it. realley - a v belt ?
The shaft is probably fatigued, so replacing the alt is in order too.
Haha for real?
