performance chip
Old Sep 27, 2009 | 05:02 PM
trourke's Avatar
trourke
Cruising
Default performance chip
I was looking at E-Bay to see what was out there and I keep seeing this chip for $25. Guaranteed to make hp. Anyone try a chip in a LT4. If so what type of result?
Old Sep 27, 2009 | 05:56 PM
John A. Marker's Avatar
John A. Marker
Save your money and go for a custom tune. You will get exactly what you paid for for $25........
Old Sep 27, 2009 | 06:30 PM
darkstallion_69's Avatar
darkstallion_69
ignore it...none of that crap works. You get what you pay for...as stated above a tune will unlock horsepower...and for giggles purchase that chip and open it up inside you will be shocked at what they are claiming makes horsepower...
Old Sep 27, 2009 | 07:14 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
AHH, AHH, ACHOO! Sorry but I am allergic to bull****.
That chip is crap. Get a custom tune if you want performance.
Anybody got some tissue? I just sprayed snot all over that generic chip.
Old Sep 28, 2009 | 05:31 AM
Paul Workman's Avatar
Paul Workman
Default Some features of a custom tune...
Mine is a custom chip with some pretty nice features...
Idle control (something we LT5 drivers have to deal with on a stock (90-91) chip.)
Cooling fan control. Mine (both) come on at about 210 and shut off at about 205
CAGS is a thing of the past.
Timing curve is modified and there is more advance - mandating premium fuel too, but well worth it!
WOT fuel to air mix is held very close to optimum across the entire RPM range.
Anti-backfire for header use
Beyond LT1/4 stuff, mine also is set to run w/o secondary throttle plates (again an LT5 thing) and operate all 16 injectors at the same time.
It runs soooooo much better than it did with the stock chip. Course it cost me a bit more than $25 (more like 17x more), but the point is, you want to have some specific ideas on what you want from a chip. Someone promoting simply "more HP" with a 'one size fits all' chip is full of it! And, FWIW, the LT4 has an E-prom in it. So, it will accept a "flash" tune w/o requiring you to touch the ECM.
P.
Old Sep 28, 2009 | 06:47 PM
trourke's Avatar
trourke
Cruising
Thats what I expected. Thanks.
Old Sep 28, 2009 | 08:34 PM
Willymo's Avatar
Willymo
What exactally will a custom tune do for a stock engine?, No headers, nothin, everything is stock.
Old Sep 29, 2009 | 07:24 AM
93 ragtop's Avatar
93 ragtop
The chip is not removeable on 94 and up vettes. So for your LT4 the computer has to be reprogrammed.
That aside, there is small gains to be made on a stock motor. Usually, it involves changing the factory t-stat (180 degrees on LT series motors) to a 160 degree t-stat. Basically, you lean out the mixture a little and advance timing a little along with lowering the operating tempature of the car, via the t-stat and the fan on settings in the program.
The factory built a very safe tune into the car for both emissions and life of the motor. For performance there is a little room for improvement.
If you are serious about doing it, check with a reputable company such as pcmforless.
Old Sep 29, 2009 | 08:14 AM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
Most are snake oil
Old Sep 29, 2009 | 08:32 AM
M.J.L.'s Avatar
M.J.L.
Turn the fans on sooner, retard the timing, few little minor things. Not much. My car is very mildy modded(no cats) but I did a custom tune and it runs better with the chip. You can always get it reflashed for 50 dollars.
Old Sep 29, 2009 | 07:04 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Thanks for the info.
Old Sep 29, 2009 | 07:52 PM
rodj's Avatar
rodj
Remember the stock tune has to accomodate all drivers; your parents going to the club on Sunday and you who wants to thrash it a bit. Has to be the best of both worlds.
http://www.fuelsaving.info/chipping.htm
Old Sep 29, 2009 | 08:25 PM
VetteTheWorld's Avatar
VetteTheWorld
Thanks for the thread, I have been investigating these "Performance" chips and its good to know this Bull.
To performance chip
