Cooling Fans
Old Sep 28, 2009 | 06:31 AM
Red-Lt1's Avatar
Red-Lt1
Default Cooling Fans
I noticed yesterday that both of my cooling fans come when I start the car. The motor is cold and the AC is on. I thought that the second fan didn't come on until the temperature reached around 238 deg. Is something wrong? It is a 94 LT1.
Old Sep 28, 2009 | 09:10 AM
enventr's Avatar
enventr
Try turning off the a/c. I believe when the a/c is on,both fans will be activated
Old Sep 28, 2009 | 10:05 AM
Goldcylon's Avatar
Goldcylon
100% correct as stated above
Old Sep 28, 2009 | 01:44 PM
DVNCI's Avatar
DVNCI
Yep - see the 3 relays on the side of radiator housing?
2 are controlled by the PCM - the other one links up to A/C - if A/C is on the relay will cause both fan's to come on, completely independently of PCM control.
Old Sep 29, 2009 | 12:28 AM
MK 82's Avatar
MK 82
Wrong. The PCM controls the fans. Period. I don't think a 94 has three relays.
Old Sep 29, 2009 | 06:23 AM
Red-Lt1's Avatar
Red-Lt1
I will look to see how many relays there are.
Old Sep 29, 2009 | 07:35 AM
RichS's Avatar
RichS
#1 relay turns the fans on low speed, then #2and #3 turn on also for high speed. All controlled by the PCM.
I know this is on a 95 and 96.
Old Sep 29, 2009 | 01:46 PM
SunCr's Avatar
SunCr
All of these Years are PCM driven based on input from the Pressure Sensor mounted on the High a/c line. The only way to see that signal is is with a Scanner. There's no gage on any vehicle that will give the pressure/temp of the stuff in the Condensor - but the PCM knows what it is based on this signal. In order for it blow cold air - or to keep it from blowing a hole in the hood - it's critical to keep the gas within a fairly narrow pressure/temperature range and that's what the PCM is doing when it drives the fans. That pressure/temp range is well below the thermostat which is one of the reasons it needs one. Coolant temperatures will be lower with the a/c on, because as you may be seeing, the fan(s) come on sooner - blow longer - and on some of the laters Years, at a much higher speed. Assuming it's blowing cold air, it's normal - if it's not, then you probably should figure out why, but in most cases it's because it's plugged up and no matter how much air flows across the condensor coils, it isn't doing what it should be doing.
Old Sep 30, 2009 | 06:16 AM
Red-Lt1's Avatar
Red-Lt1
There are only 2 relays on the side of the radiator housing
To Cooling Fans
