350 Block Question
Old Oct 2, 2009 | 04:15 PM
AstroMan1's Avatar
AstroMan1
Default 350 Block Question
I was thinking the other day, how nice it was I have a Chevy 350 and I wondered are all the 350 blocks the same? Is anything different over the years or with my 1984?
Old Oct 2, 2009 | 04:38 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
all were mostly the same from 68-91. some were two bolt main blocks some were 4 bolt mains. in the mid 80's I think they started to cast them in Mexico
Old Oct 2, 2009 | 07:44 PM
rodj's Avatar
rodj
Externally no ; internally yes.
If dealing with the late ,large journal engines (>'69),
80 - 85 got the dipstick on pass side , a change was made in '87 to a 1 pce seal crank and roller lifters in most car engines.Most GenI parts will swap '69 - '00 except crank as noted.
2 or 4 bolt mains depending on original application
LT1 is a stand alone block; heads only fit a LT1
Old Oct 2, 2009 | 08:31 PM
Paul Workman's Avatar
Paul Workman
Default A minor variation of the 350 CID small block
This is a 500 hp LT5, a fully ported variant of the stock 375 hp factory version. A special "clean sheet" project engine. Virtually everything was different except the center to center dimensions of the bores (the same as for the SBC). Available to the public from 90-95, it is (to date) the only DOHC Chevy V8 ever put in a Vette.
(Sorry... I couldn't resist!)
Just why the 96 GS draws more $$ at auction for essentially a paint job, some "bolt-on" flares, and a VIN over the ZR-1 is a mystery of the ages! Go figure!
P.
To 350 Block Question
