Problem with test ALDL
Old Oct 7, 2009 | 03:46 AM
vette83IT's Avatar
vette83IT
5th Gear
Default Problem with test ALDL
Hi!
My english is not perfect, but I hope to make me understand.
I have a question about a test ALDL for my C4 '91.
- I turn the key on start without starting the engine.
- I connect the pins A and B (as is written here http://www.corvettebuyers.com/c4vettes/codes.htm)
- the fans starting
- but the 1 flash and the other 2 flashes not appear!!!!!!
The car does not give me any code! Only the fans starting, but only the fans...
someone can give me a hand?
Thanks very very much!!!
Old Oct 7, 2009 | 05:07 AM
toptechx6's Avatar
toptechx6
Without connecting pins A & B does the Check Engine light illuminate steady when you turn the key to the "ON" position?
Old Oct 7, 2009 | 08:48 AM
vette83IT's Avatar
vette83IT
5th Gear
Hi toptechx6! thanks for the answer.
Yes, the light "Check Engine" is illuminate steady, and after few second, disappear.
Old Oct 7, 2009 | 01:35 PM
IslandPirate's Avatar
IslandPirate
ground pins A and B BEFORE you turn the ignition to "ON"
Old Oct 8, 2009 | 02:10 PM
vette83IT's Avatar
vette83IT
5th Gear
yes yes island pirate.... before before
today i open behind the led panel..... and i find a mess..... cutted wires, wires with scotch.... OMG....
next week i'll take my vette to the dealer and do a test with a computer, plugged to the ALDL pin.
To Problem with test ALDL
