Coolant Light
Old Oct 25, 2009 | 10:53 PM
95VetteMan1's Avatar
95VetteMan1
Default Coolant Light
I have a question for someone. My coolant light is coming on every now and then, Coolant level is ok, and temparature is ok...any sugestions?
Old Oct 25, 2009 | 11:27 PM
jfb's Avatar
jfb
Coolant below opening temp of the thermostat or engine off, you cannot look into the radiator filler and see if you are low on coolant which causes the coolant light to come on intermittently. This is because the engine is lower than the radiator top and air stays in the upper part of the engine and the radiator always looks full. C4's have to be, "burped", that is, the trapped air must be replaced with coolant. Older C4's you turn the rad cap to its first notch and let engine idle to the opening temp of the thermostat, then race the engine slightly and slowly open the rad cap (in that order). Look into the rad, you will see the coolant level drop if there is air in the engine. If it drops, keep the engine revs up and pour coolant into the filler until it is full, replace the rad cap and let the engine back down to idle. If you have had the coolant drained, air also gets trapped in the heater core and you might have to burp several times to get all the air out of the system. Next, always have at least 1/2 the overflow bottle filled with coolant, if it runs out of coolant, then it starts pulling air into the cooling system as it cools down and you will get the low coolant light. If the coolant level stays full during the test I described, then you might have a defective low coolant sensor in the radiator. Later C4's have a screw at the thermostat housing that you loosen to let air out of the system while the engine is running.
Old Oct 26, 2009 | 12:15 AM
95VetteMan1
Thanks for the info...Will follow your instructions...
Old Oct 26, 2009 | 01:37 AM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Feel free to correct me if I am wrong but in the OPs 95 you cannot look into the radiator. if the coolent falls below the lower overflow hose in the surge tank the coolent light will come on.
Follow the procedure outlined above withthe following modification. with the engine cold, remove the pressure cap from the surge tank and start the car. Let it idle until the thermostat opens and the fluid may then drop to it's "natural level". Let the engine cool and fill until coolent reaches the level of the upper overflow hose and starts trickling into the overflow plastic tank behind the passenger front wheel. Replace the pressure cap.
If the light comes back on repeat the process as necessary
Old Oct 26, 2009 | 08:46 AM
tblt44's Avatar
tblt44
While it's running BURP it with the small brass bolt on pass side above water pump.Don't get the opti wet,put a rag under the bolt
Old Oct 26, 2009 | 02:45 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Make sure you used the proper sized flathead screwdriver to loosen said brass bolt, too. It's a soft metal and easy to distort the screw head.
Old Oct 30, 2009 | 12:33 AM
95VetteMan1
Thanks Guys for the Info!
To Coolant Light
