Odd Lights
Old Oct 26, 2009 | 09:48 PM
bk84vette's Avatar
bk84vette
Default Odd Lights
So i took the 'vette out today and as I turned the parking lights on (as I always do), I noticed the left indicator on the dash was lit up and wouldnt go off. Upon further investigation i noticed that the very front amber, as well as the side amber light on the front left were off when the swtich was turned on. When I turn the left turn signal on, the two ambers that were off before come on as well as the white light on the side, but they do no blink. When I flip the headlights up there is no change and the right side of the car seems to be fine..... any suggestions as to what may be going on?
Thanks!!
Old Oct 26, 2009 | 09:51 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
either a bulb is out in the rear. or a flasher is bad.
Old Oct 26, 2009 | 09:57 PM
bk84vette's Avatar
bk84vette
ah, ok. Would the backup lights right beside the license plate do it? I was messing with those this weekend and maybe i didnt get it back in right...
Old Oct 27, 2009 | 03:49 PM
Nowhere Man
it shouldn't its not on the same circuit. do all your tail lights work
Old Oct 27, 2009 | 04:23 PM
bk84vette's Avatar
bk84vette
yeah all the tailights seem to be working fine.
Old Oct 27, 2009 | 04:26 PM
Nowhere Man
so you are saying your tail light flash when you hit the signal while your front lights are solid.
Old Oct 28, 2009 | 10:59 AM
bk84vette's Avatar
bk84vette
oh sorry, no the tail lights do everything but flash.
Old Oct 28, 2009 | 11:25 AM
Goldcylon's Avatar
Goldcylon
Replace the flasher
Old Oct 28, 2009 | 06:53 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Old Nov 1, 2009 | 08:07 PM
bk84vette's Avatar
bk84vette
ok, I replaced the flasher and now all the lights flash as they are supposed to!
The only problem that I still has is the parking lights.... The front and side amber lights only on the left side still dont light up. The rear side and back lights work fine on the left, as do all the other lights around the car. Also the left turn signal indicartor on the dash is on all the time (when the lights are turned on).
I have taken all the lights out and put them back in to see if one was loose like "Nowhere Man" said. Also, none of them are burnt out...
Old Nov 4, 2009 | 09:57 AM
Goldcylon's Avatar
Goldcylon
Check the ground wire on that side. Run a muli-tester in the socket
Old Nov 6, 2009 | 08:14 AM
bk84vette's Avatar
bk84vette
So i finally found to problem! There is a wire that goes into the parking light unit that was popped out (maybe a ground wire). The connector on the wire is broken, but when i shove the wire back up in there everthing works just fine! Im going to get a new one today and porblem solved! Thanks for all the help guys!
Old Nov 6, 2009 | 11:55 AM
flynn508's Avatar
flynn508
I wish all my problems were that easy to fix!!
Old Nov 6, 2009 | 02:29 PM
bk84vette's Avatar
bk84vette
$0.57 at Napa, and about 10 minutes to replace the connector and put everything back! Gotta love those fixes!
To Odd Lights
