Front leaf spring replace
Old Oct 28, 2009 | 03:20 PM
illenema's Avatar
illenema
Default Front leaf spring replace
Anyone have a link from someone who has done this??
Old Oct 28, 2009 | 03:45 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
VIA Vette Brakes --> http://www.vbandp.com/instructions/h...t/31302-32.htm
Good Luck.
Old Oct 28, 2009 | 07:13 PM
illenema's Avatar
illenema
Originally Posted by shakedown067
Thank you.
Old Oct 28, 2009 | 07:34 PM
jimg's'93's Avatar
jimg's'93
I installed the front spring when I removed my coil-overs and used those same instructions. It's a very easy job, just be careful.
Old Oct 28, 2009 | 08:17 PM
StealthLT4's Avatar
StealthLT4
I don't know about easy ... some parts are a serious PITA! Namely re-installing the nuts on the spring retainer brackets, as the bolts spin (why not just make them U-bolts?) as you try to tighten the nuts. I got around this by using a pair of needle-nose vice-grips to hold the bolt as I open-end-wrenched the nuts on.
Old Oct 28, 2009 | 08:27 PM
jimg's'93's Avatar
jimg's'93
Ok. Maybe it's not 'easy' but I really didn't encounter any problems, it just took time and patience.
To Front leaf spring replace
