1996 Corvette Programmer
Old Oct 29, 2009 | 04:39 PM
castel24's Avatar
castel24
3rd Gear
Default 1996 Corvette Programmer
Looking for information: 96 C4
My A/C-Heather Vents only blow air from top and bottom.
No air coming out of the front vents.
Anyone have or had this problem.
I replaced check valve on engine, and good suction at
the check valve posts.
All signs are leading to the programmer.
Any advice?
Thanks,
Castel24
Old Oct 29, 2009 | 06:12 PM
RLG's Avatar
RLG
sounds like the programmer. Mine needed to be replaced.
Old Oct 29, 2009 | 06:16 PM
grinditout's Avatar
grinditout
probably not the programmer board , but the softg nipples , do your research.
Old Oct 29, 2009 | 06:34 PM
RLG's Avatar
RLG
grinditout may be right, my 90 has the hard plastic nipples, they went to a soft rubber sometime after that . the nipples become soft and the vacuum collapses them.
Old Oct 29, 2009 | 06:54 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Some good info here:
http://forums.corvetteforum.com/c4-t...l-problem.html
Old Oct 29, 2009 | 07:06 PM
Klondike's Avatar
Klondike
Had a similar problem and followed the above recommendations and it's fixed. Switches the air as fast as the buttons are pushed.
Had to take out the driver seat, lay on my back with my head under the dash and my feet in the hatch area, but I did it myself.
Old Oct 30, 2009 | 06:31 AM
harley 1951's Avatar
harley 1951
I had same problem. Had Indy experts sell me all kiknds of expensive electronics, still blowing out defrost . Took to dealership and they filled vac system with smoke and found rotten hose. couple bucks for new hose, lots a bucks for dealership expertise, but well worth a working A/C .
Old Oct 30, 2009 | 08:09 AM
runner140*'s Avatar
runner140*
Read and print post #5. You'll have to pull the drivers seat, pull the kick panel and the problem is on the fire wall....up from the gas pedal.
The programmer/controller is round, 1 1/4" in dia. and has five vacuum hoses attached to the face. The problem is the connection nipples have collasped from heat and age and have to be trimmed back.
There is very little room to work and most has to be done with one hand.
Get back to us when you get started for additional help/info.
It looks like this (not round?):
Old Oct 30, 2009 | 10:09 AM
Klondike's Avatar
Klondike
Take a look at the above post. Those little nipples that the guy is touching with the screw driver is what everybody is talking about. With that little box out from under the dash (the hard part), it is easy to work with on your work table. I replaced all those little things with tiny pieces of brass tubing from a local hobby shop, and tipped them with some of that plastic tubing that hospitals use for the oxygen breathing tubes. Same length & diameter stuff as original but won't collapse under vacuum. There isn't any flow in there, just a vacuum pull on some diaphragms to open and close door flaps. Inside that little box are some solenoids that open and close some valves to direct vacuum to those tubes. I opened and cleaned those with alcohol and re-lubed them with a little smear of Vaseline. May not need to go that deep, but I'm kind of **** about stuff I never want to work on ever again.
Old Oct 30, 2009 | 03:25 PM
Wathen1955's Avatar
Wathen1955
For those that have done this, is it important to replace the removed vacuum line in the on the same nipple where it was removed? If so, do you mark them with tape so they go back in the same spot?
Old Oct 30, 2009 | 04:11 PM
castel24's Avatar
castel24
3rd Gear
Thanks for the info.
I agree, it would be great to get it out, and work on the bench.
I see it under the dash, how hard is it to get out. I do see one nut/bolt
and a wire harness attached, does that come into play?
Any advice on the removal?
Thanks,
castel24@aol.com
Old Oct 30, 2009 | 05:20 PM
Klondike's Avatar
Klondike
Thanks,
castel24@aol.com
Yes, that's the tough part. That nut holds it to a bracket under the dash and that little harness has to be unplugged from it too. Then, after a few skinned knuckles and dust falling in your face, you can get it out. The little vac lines are color coded, and the plug nipples are numbered, so make a note of where they go if you take them off. If I remember correctly, the vacuum harness that plugs into that box is keyed and will only go back on one way.
Look back at post #5 here and click on the link. Once there scroll down to post #13 and it shows more detail about that little vacuum control box. It makes a lot more sense once you get the Vac & electrical harnesses off and the box out of there where you can see what your doing.
Old Oct 30, 2009 | 08:32 PM
pianoguy's Avatar
pianoguy
It'll only go back on one way - in the picture shown, the cutout where the vacuum harness fits in is the same shape as the connector.
The vacuum harness is held on by a ridiculous little push-nut. I used a small blade screwdriver to pry the push-nut out a bit until I could grab it with a needle-nose pliers, and then twisted it until it broke. I used a small nylock nut to put it back together.
To 1996 Corvette Programmer
