After draining the coolant thru the knock sensor holes, is it necessary to
use a SEALANT of some sort on the sensors when re-inserting them
back into position? Thanks
I've pulled my knock sensors twice and reinstalled them without adding any sealant, and have had no leaks. If you're installing new sensors and they don't have any sealant, then by all means you will need to apply some to the threads.
"NOTICE: Do not apply thread sealant to sensor threads. Sensor is coated at factory and applying additional sealant will affect the sensors ability to detect detonation"
Curiosity question only. What is the advantage for one to drain the coolant through the knock sensor? Looking at your profile shows you have a LT1. Is it also a good thing to do the same to a LT4 and if so what other year 'vettes would this be applicable too? Thank you in advance.
BTW I agree with the not applying anything to the threads of the knock sensor for the various sstated reasons.
Olcrusty
The very knowledgeable Forum Members have said this is the way to
completely drain the block. Otherwise, quite a bit remains in the system.
Ive never bothered putting anything on the threads, and ive never had one leak either. Make sure you do them up to the right torque as specified in the genuine GM service manual.
100% correct. That is exactly why. When you dont remove them, the block will stay completely full, and the most youll ever get out will be the amount that will flow from the lowest hose you remove. The hoses are not that low. The knock sensors are at the lowest point of the cooling system ( as far as the engine side of it is concerned )
If this is an LT1, draining the radiator will do just that and nothing else. The main inlet and outlet on the LT1 water pump are abit higher than both the pump and the block, so at best, you will get a bit out of the heads, but again not all of it.
Water wont flow up hill, and neither will coolant.
It is a 1/4 NPT (pipe thread).
Without some type of thread sealant, you are taking a chance on it leaking. If I reuse a sensor, I clean off the residual red sealant applied by GM, and re-apply a very thin coat of liquid teflon.
Pete, I do agree. If you clean the threads completely and start fresh, your more likely to keep the semsor's original sensitivity than if you were to apply additional sealant. Personally, I wouldn't feel I'd done a proper job if I didn't reseal the threads.
Olcrusty
As the others stated, this is the best way to do a nearly complete drain of the system. The other method I've used is to open the surge tank and use my shop vac to blow the system clear. It does a pretty good job, but removing the knock sensors would still be best IMO.
Any Idea what this (Red Sealant) might be?
Can we purchase this from a parts house/GM?
