What's your trick...
Old Nov 11, 2009 | 11:41 AM
Vette73's Avatar
Vette73
LS/MFT
St. Jude Donor '09-'10-'11-'12
Default What's your trick...
for sealing the rear of the L98 intake?
This month's Corvette Fever (Jan 2010) had two questions related to this problem in the "Wear & Tear" Q and A section. As anyone with an L98 knows, getting a good oil-proof seal on the rear of the intake can be a challenge and many tricks and techniques have been tried. I once had someone suggest that the block should be dimpled with a punch at 1/4" intervals to ensure a good seal.
So how 'bout it: what method have you used that you've found works over the long term?
Old Nov 11, 2009 | 01:09 PM
Inlove's Avatar
Inlove
I googled that yesterday as I am tracing an oil leak of my own. The dimpling method was mentioned, thanks for explaining what it was. The main consensus was the use of Felpro gaskets and Permatex's The Right Stuff. Dimpling sounds too extreme for me so I may just rough the surfaces. Also mentioned several times was to give the sealant the proper time to cure.
http://www.permatex.com/products/Aut...sket_Maker.htm
Old Nov 11, 2009 | 02:24 PM
Aardwolf's Avatar
Aardwolf
I've had mine apart several times and had no trouble just using RTV and nothing else special. I've found the single biggest thing to be placing the intake on straight and not shifting it around. It's easy to disturb the bead.
Edit, normal RTV has always sealed fine for me and the right stuff product is very high priced so I haven't tried it.
Old Nov 11, 2009 | 04:28 PM
Churchkey's Avatar
Churchkey
Never had a leak in 600+ hp oval track engines.
Dimple the block rail & the intake manifold where it sits on the rail with a punch & hammer.
Use cork end seals. If the gasket set does not come wiith them make them from a sheet of cork. Check the fit & trim the cork as needed to fit the rail & intake gaskets.
Clean all surfaces with a good solvent.
Install the port gaskets & use manifold bolts to hold the location. This assuming you are using Felcro blue gaskets without gasket sealer.
Apply a bead of 3M yellow super weather strip adhesive (Gorilla Snot) to the end rails & immediately install the cork seals. Monitor the corners or place a weight on the corners to hold them in place. Allow 20 minutes set time.
Next install a bead of RTV silicone on the cork. Use extra RTV at the corners. Let the RTV set up about 10 minutes.
Install the manifold.
Old Nov 11, 2009 | 05:22 PM
engle1147's Avatar
engle1147
Clean the surfaces then use Permatex's "The Right Stuff"
Old Nov 11, 2009 | 07:29 PM
John A. Marker's Avatar
John A. Marker
Dimple the "china walls" with a center punch, dimple the rear and front of the intake manifold also, clean several times with lacquer thinner and then use 3/8" bead of THE RIGHT STUFF.
Old Nov 11, 2009 | 07:53 PM
jmrl98's Avatar
jmrl98
I'm a dimpler also - and I used the right stuff too. Very sound advice, as even with the dimples, regular black permatex didn't do it (leak at rear), so I used the right stuff and that did the trick. I'm going to find out soon how hard it is to remove the manifold after the right stuff, and it doesn't thrill me...
Old Nov 11, 2009 | 08:10 PM
TA's Avatar
TA
Nothing I've sealed with "the right stuff" (including two L98 intakes) has ever leaked a drop.
I'm sure putting dimples in stuff might help, but I haven't had a problem without doing it.
To What's your trick...
