Headlight noise question
Old Jan 20, 2010 | 03:00 PM
Camelotian's Avatar
Camelotian
Default Bushings
Originally Posted by tblt44
Ok I'm getting a white poeder residue under the motors.
Could it be the bushings andd gears or just bushings.
Looks like I can take the cap of the motor where the gears are without pulling the whole thing out.
Any help on this fix would be great.
Bushings are only 5 99 for each light.geras are 29 each or 59 for bronze
You have to remove the light canister and take the motor off in order to get it apart (because of the cotter pin). The bushings have turned to powder, as did mine. There are several fine threads on replacing the bushings.
Old Jan 20, 2010 | 06:14 PM
tblt44's Avatar
tblt44
I was hoping I could fix them on the car
It would make life much easier
Old Jan 21, 2010 | 08:49 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Nope. You'll have to remove to repair. The first side, you'll climb the learning curve. By the time you get to the opposite lamp, you'll be a master.
Put a cotton towel on your workbench so you don't scratch the finish on the headlight bucket and take your time. It's a good Saturday project where man bonds with machine.
Old Jan 21, 2010 | 09:22 AM
MostWanted's Avatar
MostWanted
Originally Posted by Matthews1stvette
Mine do the exavt same thing. I asked the dealer about it and they told me they are fine. Its just the motor cycling as it ages.
I can't believe they told you they were fine. Idiots. Why can't they just admit when they don't know.
Old Jan 21, 2010 | 11:26 AM
Sheri'sCherry87's Avatar
Sheri'sCherry87
my headlights don't make any noise at all after they close
Old Jan 21, 2010 | 11:33 AM
onedef92's Avatar
onedef92
They will. It's only a matter of time. All Delrin bushings turn to doody by design....
Old Jan 22, 2010 | 02:09 AM
Sheri'sCherry87
great!.. now i have asteroids colliding with the earth AND that to worry about!!
Old Jan 22, 2010 | 09:25 AM
onedef92's Avatar
onedef92
No sense worrying about shet you can't control. But replacing the headlight bushings is easily within the means of all 1987-96 C4 owners.
