Option Code 'Black Book'
Old Mar 2, 2002 | 06:28 PM
linkschamp's Avatar
linkschamp
Default Option Code 'Black Book'
Hi,
Does anyone have a copy of the "Black Book" which defines the
build codes? I know one of these books can be purchased from
the Corvette Musuem (along with build sheet/window sticker) but
I would like info on the codes asap.
I have a complete list of my 92 codes I can email rather than post
them all in the forum...
Any help is appreciated!
NB :rolleyes:
Old Mar 2, 2002 | 06:46 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Option Code 'Black Book' (linkschamp)
Post 'em! You gotta type it up either way. I'm not the only one who will take a shot at it. I hope you are refering to the rpo codes for your 1992 Corvette, and not a build sheet contaning a quantity of 92 codes. Either way, bring it on!
Old Mar 2, 2002 | 06:56 PM
linkschamp's Avatar
linkschamp
Default Re: Option Code 'Black Book' (CFI-EFI)
Thanks & Take Your Shot!
AC1
AC3
AJ3
AR9
BGR
CF7
C68
DL8
D78
D8K
E52
392
FE1
GM1
IP3
JL9
KW2
LT1
MD8
MX0
NA5
NK4
QA1
UX0
UIF
U52
U75
V73
XAU
YAU
1AY
1SB
101
10U
103
199
:seeya
Old Mar 2, 2002 | 08:06 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Unfortunately the Black Book is not the best source for decoding, it only has general information and a handful of codes.
I used to have a slew of websites for decoding, but I lost them all when I put in my new Hard Drive.
Rotties page and The Viper Pit have most of the RPO codes listed, do a search and maybe one of those pages will turn up.
Old Mar 2, 2002 | 10:02 PM
Scoob's Avatar
Scoob
You had a couple typos that I took the liberty of correcting.
RPO Code Description
AC1 ADJUSTER, PASS ST, POWER, 6 WAY, BKT
AC3 ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AJ3 RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AR9 SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
BGR BOWLING GREEN PLANT PROCESSING
CF7 ROOF, SUN REMOVABLE NON-TRANSPARENT
C68 HVAC SYSTEM, AIR CONDITIONER FRT AUTO, ELECTRONIC
DL8 MIRROR, O/S LH & RH REM CONT, ELEC, DEFOG
D7B GEAR, SPEEDO DRIVEN (D78)
D8K SENSOR, VEH SPD (D8K)
E5Z SPEEDOMETER ADAPTER (DELETE)
E9Z SPEEDOMETER KEY (DELETE)
FE1 SUSPENSION SYSTEM, SOFT RIDE
GM1 AXLE REAR, 2.59 RATIO
IP3 Trim, Interior Design (P3) (Base w/AR9)
JL9 BRAKE, SYSTEM, PWR, FRT a RR OISC, ANTILOCK, FRT W
KW2 GENERATOR,124 AMP
LT1 ENGINE, GAS, 8 CYL, 5.7L, MFI, HO
MD8 TRANSMISSION, AUTO 4 SPD, THM 700 R4
MXO MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5 EMISSION SYSTEM, FEDERAL, TIER O
NK4 STEERING WHEEL, SPORT LEATHER
QA1 WHEEL, 17 X 9 S, ALUMINUM, STYLED
UX0 SPEAKER SYSTEM, 4, DUAL FLR SILL, DUAL EXTD RANGE
U1F RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
U52 CLUSTER INST, ELECTRONIC
U75 ANTENNA, POWER, RADIO
V73 VEHICLE STATEMENT US/CANADA
XAU TIRE FRONT, P275/40ZR17/N BL R/PE ST TL HW4
YAU TIRE REAR, P275/40ZR17/N BL R/PE ST TL HW4
1AY ORDER MODIFICATION STOCK
1SB Option Package 02
10I INTERIOR TRIM, ARCTIC WHITE (93)
10U PRIMARY COLOR , EXTERIOR, ARCTIC WHITE (91)
103 TRIM COMBINATION, LEATHER, ARCTIC WHITE (93)
199 SEAT BELT COLOR, BLACK (91)
73I INTERIOR TRIM, FLAME RED (I) (91)
81U PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
To Option Code 'Black Book'
