I have a Black 1985 vette and I would like to know where I can get some Door pnls as they are pulling away from the door. Also what is a good price for fixing a exuast pipe that has broken away from the muffler or to replace the whole thing.
This link is to a door panel repair.
I don't know if the 85 is the same as the late C4's but could give you some Idea's and save you about 1k on new door panels
Thanks for the replys that helps a lot. Another interesting problem maybe you guys have experianced it. I was unable to start my car lights would come one digital display would work but I could not get the car to start nor did I hear a clicking sound of the solinoid. I took the battery into autozone and it was bad. I replaced it and took the new one home installed it and the car worked. The next day I go to start the car it dose not start same issue. A few days later I try to start my car and it starts for some reason I drive it over put air in the tires take it home wash start it again and then put it into the garage. This morning I go to start it to go to work dose nto start same issue. Dose my car have a spirit resideing in it.
My door panel was pulling away on the drivers side and the dealer wanted $600 + to fix it. I took it to an upholstery shop and he did it for about $30 and three years later it is still O. K. I do not know if this will work, but for the money it might be worth a try.
Sounds to me like starter is bad. If it gets a bad spot it may be intermittent - mine was the same way. It was like the lottery whether or not it would start on a given day. Luckily starters are cheap.
Door panels are pricey for sure, going through the same issue with mine in trying to restore - I've been watching ebay and craigslist (www.craiglook.com for searching all craigslists) for a good used set and have managed to find a passenger one and now need the driver's. Will just be patient and hope one comes along . Good luck!
