Suspension question
Old Jan 20, 2010 | 07:11 PM
USAFPILOT's Avatar
USAFPILOT
Default Suspension question
My 94 will squirm to the left when I let off the gas and then back to the right when I get on it.
Any guess to why?
Could it be the C Beam, or is something else loose under it?
I think the car is leaning towards the passenger side about a half inch based no the gap between the rear tires and fender on each side.
The car is a ZR-1 and I drive it hard.
Old Jan 22, 2010 | 08:59 AM
Richard G.'s Avatar
Richard G.
My 94 LT1 breaks a little to the right on acceleration. Never to the left. Of course your engine has more cubes.
I would take it to a good alignment shop or a good mechanic and drive it easier till you find the answer.
Old Jan 22, 2010 | 09:19 AM
aminnich's Avatar
aminnich
I would check the trailing arm bushings.
Old Jan 22, 2010 | 09:32 AM
mashinter's Avatar
mashinter
and the toe links (rear steering linkage)
Old Jan 22, 2010 | 02:09 PM
Frizlefrak's Avatar
Frizlefrak
Any one of a number of suspension issues could be causing this. Your 94's suspension is now 16 years old, and the bushings (if original) are probably either rock hard or have turned to mush, probably the latter. Check the following...if needed, replace with poly and lube generously with silicone grease.
Batwing bushings
Trailing arm bushings
Strut rod bushings
Sway bar bushings
Rear tie rod assembly (toe link) and ends.
Check for any play and replace parts as needed, finish off with 4 wheel alignment. That should cure the problem.
Old Jan 22, 2010 | 02:18 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
I'd check the rear bearings as well.
Old Jan 22, 2010 | 04:59 PM
Richard G.'s Avatar
Richard G.
These guys are giving you good information.
Be sure and take it, fly slowly.
Old Jan 22, 2010 | 08:22 PM
Churchkey's Avatar
Churchkey
In addition to the good advice already posted.
Suggest checking the circumference of both rear tires & compare the measurements.
Posi traction, lockers, ratchet drives etc need a matched set of tires.
A 1/4 x 8' tape works best & is comonly called a stagger tape @ the track.
To Suspension question
