Convertable X Brace
Old Jan 28, 2010 | 03:21 PM
CAJUN C4's Avatar
CAJUN C4
Default Convertable X Brace
Will a vert X brace fit on a Coupe? And will it stiffen it up any?
Old Jan 28, 2010 | 03:32 PM
BobRR3's Avatar
BobRR3
The X Brace will fit and bolt up at the four corners however, The vert has 8 more mounting points on the undercarriage. the coupe does not have these.
I guess you could add them
Old Jan 28, 2010 | 03:59 PM
CAJUN C4's Avatar
CAJUN C4
Thanx...I was just curious.I've never seen one before.
Old Jan 28, 2010 | 04:15 PM
StealthLT4's Avatar
StealthLT4
I have one sitting in my garage that I've been meaning to install on my '96 coupe, just haven't gotten around to it. I think it'll have to wait til it becomes a dedicated (mostly) track car, since it removes 1" of ground clearance, and I'm already lowered.
Old Jan 28, 2010 | 04:25 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
The front mounting holes are there but there rears are not. You'd have to drill holes and install threaded inserts for the rear. You also lose almost 2" of ground clearance with the stock X-brace. I've heard of a few that modified them so they hug the floorpan better and it's around an inch of clearance lost. I thought about getting one for mine, but like Stealth, I'm lowered. Thinking about talking to my chassis guy and seeing what it'll cost me to have a tubular one built.
Old Jan 28, 2010 | 05:13 PM
pologreen1's Avatar
pologreen1
you'll scrape on streets with it for sure if it is lowered. This is why I did not lower this vert. I looked at it and realized what I would be getting in to around here.
Old Jan 28, 2010 | 09:02 PM
86PACER's Avatar
86PACER
The vert also has several protruding threaded studs towards the center undercarriage that pass through the brace also, not just the holes at the corners.
Old Jan 28, 2010 | 10:48 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I put one on my '85 coupe and I had to make the front mounts. The '84-'85 did not have the mounting area that started in '86. Anyway, I also boxed mine and it made it even better. My car is lowered too and yes, I do scrape on occasion but since I boxed the brace it acts like a skid plate now and just goes right over the high spots with no damage to the brace. Now I can jack up one corner of the car and bring 3 wheels off the ground.
Old Jan 28, 2010 | 10:58 PM
littlesk8cracker's Avatar
littlesk8cracker
uh oh, i have one on my vert (obviously) and i wanted to lower my car about an inch in the spring. i take it slow and have never scraped it, but i wonder how careful ill have to be if i lower it
Old Jan 28, 2010 | 11:14 PM
86PACER's Avatar
86PACER
Pics?
Old Jan 29, 2010 | 01:07 AM
pologreen1's Avatar
pologreen1
had Now I can jack up one corner of the car and bring 3 wheels off the ground.
It makes it so easy to jack them up, and yes one spot lifts the whole car up, I love mine, I would have it on a coupe also.
Old Jan 29, 2010 | 07:51 AM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
Where do you put the jack ?On the x brace bolts?
Old Jan 29, 2010 | 01:16 PM
pologreen1's Avatar
pologreen1
The brace is not flat. It has angles on it that come down from bolting points and then the brace funs underneath the trans and stuff. I usually put the jack on the corner of the brace. My car has a body kit, so I have real low profile jacks, but they barely barely fit under the car.except from the rear. I am going to make ramps some day that will work. My standard ramps are too high, and too skinny.
Old Jan 29, 2010 | 05:53 PM
Midnight 85
Originally Posted by 86PACER
Pics?
I did a complete write up with pics some time back. I don't have those pics any more but maybe someone kept them ot has a link to that thread. Basically you just put flat stock on the "open" side of the brace leaving spaces for bolt access. Sorry I don't have the pics any more.
Old Jan 29, 2010 | 06:01 PM
pologreen1's Avatar
pologreen1
This is all I found from you so far.
http://forums.corvetteforum.com/c4-t...-85-coupe.html
Old Jan 29, 2010 | 07:53 PM
aboatguy's Avatar
aboatguy
I don't understand all the I'm lowered so I can't use an X brace comments.
X brace will stiffen up your coupe..but a factory hardtop will stiffen a vert even more...
Midnight 85
Type "boxing the x brace" into the search, it turns up some more info and a picture of another members car who also boxed his brace. It will give you an idea of what I did. I have no idea where those pics went here on the forum, a computer snafu took care of the files I had.
This thread has one pic of another members boxed brace, http://forums.corvetteforum.com/c4-t...ngthening.html
To Convertable X Brace
Old Jan 29, 2010 | 08:01 PM
86PACER's Avatar
86PACER
Originally Posted by Fastmax32168
I boxed mine using sheet metal the same thickness as the brace. Definitely made a big difference in the strength of the brace. That coupled with a homemade cross brace and a camber brace has really solidified the feel of my car.
This one? Looks like a DIY R&D cross frame conversion. Pretty cool.
Old Jan 29, 2010 | 08:49 PM
shakedown067
HOLY CRAP THAT'S LOW. You don't have issues over speed bumps or driving around town? I already scrape over stuff...I guess it's just a crossmember right...
Old Jan 29, 2010 | 09:12 PM
pologreen1's Avatar
pologreen1
I have a body kit, and roads suck.
