Ride control question
Old Feb 14, 2010 | 06:01 AM
Disarray_kid's Avatar
Disarray_kid
Default Ride control question
Ok I had my ride control tested. Every code that is has show up even after resting the computer. On tour it work with no problems. I set it to sport the service ride control light comes on after going over a bump. and just pulling out of the drive way on the last setting it goes off right there and then.
Has this happen before? I drive a 1990 C vette with the L98 6 speed.
Old Feb 14, 2010 | 09:33 AM
j-vette's Avatar
j-vette
St. Jude Donor '10
I think everybody here knows what you drive by now...
You say you had it tested. What was the opinion of the mechanic you took it too?
Old Feb 14, 2010 | 10:05 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
this may not fix it if you have a bad shock but try unhooking the battery, this will reset everything. If the light comes back on run the codes it will tell you what shock is setting the code.
Old Feb 14, 2010 | 04:40 PM
Disarray_kid
can't blame me for loving my vette and letting everyone know what I drive. the mechanic said he want to cut my wire harrness till he find the problem. I am looking for another opinion if you know what I mean.
Old Feb 14, 2010 | 04:41 PM
Disarray_kid
the shock look new and I had the battary unhooked before and still. But what is weird is the fact that every code that my ride control has show up.
Old Feb 14, 2010 | 04:53 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
I totally know what you mean. A statement like that make's it sound as though they don't know what they are doing... Definitely get another opinion
Old Feb 14, 2010 | 06:35 PM
Red Dwarf's Avatar
Red Dwarf
The codes will have to be cleared. I think you have to ground pin "C" 3 times within 10 seconds using the DLC.
You can check for codes using "A" to "C". Sounds like your familiar with the paper clip method?
Old Feb 14, 2010 | 07:23 PM
Disarray_kid
You can check for codes using "A" to "C". Sounds like your fasmiliar with the paper clip method?
not one bit
lol I had a chevy tech use a obd 1
Old Feb 14, 2010 | 08:41 PM
Jon Hekking's Avatar
Jon Hekking
Don't let him do that It sounds like you need a different mechanic.
What does it do at 40 MPH?
Old Feb 14, 2010 | 08:59 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
<coke spew>
Old Feb 14, 2010 | 09:07 PM
Red Dwarf's Avatar
Red Dwarf
not one bit
With a little study you can pull the codes yourself.
Read the site thoroughly & then you can decide if you want to try it?
Personally I'd take a shot at it. Remember "A" to "C" for FX3
If you get anything post it.
http://www.corvettephotographs.com/c4vettes/index.htm
Old Feb 14, 2010 | 11:26 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
the mechanic said he want to cut my wire harrness till he find the problem. I am looking for another mechanic if you know what I mean.
Fixed.
Old Feb 15, 2010 | 11:42 AM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
fixed hmmmmm
Old Feb 15, 2010 | 05:18 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Check out this site
http://captainzcnc.com/index.html
Old Feb 16, 2010 | 12:21 AM
Disarray_kid
I got to work on tuesday but the day after I can do it. I'll post what codes I get and read out of the big red book I got for my car.
Old Feb 16, 2010 | 06:44 AM
Swedish Hot Rod's Avatar
Swedish Hot Rod
FX3 was not working on my -92, turned out to be a faulty FX3 control box.
Here is a very nice article about the system http://corvetteactioncenter.com/tech/c4/fx3/index.html
To Ride control question
