Automatic shift knob links......
Old Mar 8, 2002 | 12:56 AM
OrangeC4's Avatar
OrangeC4
Default Automatic shift **** links......
I have seen lots of questions about shift ***** for automatic, here are some links:
http://sportscar-parts.com/mivastore...ct_Code=mmauto
http://nextcollection.com/html/ORD-A...-1609-none.cfm
http://inlinefour.com/razautstylsh.html
http://www.anthonysupholstery.com/tonyknobs3.html
http://www.rksport.com/rkstore/dept....cssid=&x=6&y=7
They don't say that they work with a vette, but I have called and they told me the size of them and they will work.
[Modified by OrangeC4, 4:57 AM 3/8/2002]
Old Mar 8, 2002 | 08:38 AM
Bradley3's Avatar
Bradley3
Default Re: Automatic shift **** links...... (OrangeC4)
Thanks for the links!!!
Do you know if any modification will have to be done to install? And how difficult the installation is?
Old Mar 8, 2002 | 11:34 AM
jwade91's Avatar
jwade91
Thanks for the links. I like that MOMO **** quite a bit.
Old Mar 8, 2002 | 11:39 AM
OrangeC4's Avatar
OrangeC4
Default Re: Automatic shift **** links...... (Bradley3)
Most of them go on with three screws, that you screw into the side of the shaft of the shifter clamping it down. Real easy install, takes 5-10 mins.
To Automatic shift knob links......
