Running cooler
Old Mar 8, 2002 | 01:32 AM
linkschamp's Avatar
linkschamp
Default Running cooler
I have a '92 LT1. I've heard they tend to run hot. I've also heard about
aftermarket low-temp thermostats - especially those mated to Hyper-chips.
My question is... can a high-performance thermostat (say 160-180 range)
be added as a simple upgrade by itself or must it be mated to one of the
chips and or programmed?? Anyone make such a simple change?? :rolleyes:
Old Mar 8, 2002 | 02:09 AM
CowboyNVette's Avatar
CowboyNVette
Default Re: Running cooler (linkschamp)
If you just add the thermostat then your cooling fans will not come on till you reach the higher temperature that you are trying to stay away from. To achieve a lower operating temperature you need to have your fans turn on at a lower temp. I am not sure on the 92 which method you have to do but on the 96 you have to reprogram.
Old Mar 8, 2002 | 05:53 AM
dmalhi1's Avatar
dmalhi1
Default Re: Running cooler (CowboyNVette)
well isn't there just a switch or something you can install which would turn on the fan sooner than it would as it approaches max temperature ?
Old Mar 8, 2002 | 08:06 AM
CowboyNVette
Default Re: Running cooler (dmalhi1)
Yea, but I think that is just a manual fix. I think he was asking about something that would automatically adjust his car to lower operating temps.
Old Mar 8, 2002 | 11:17 AM
linkschamp's Avatar
linkschamp
Yes, you're right - manual is out of the question, too easy to forget to turn
them on and bam! However, replacing the stat would allow for cooler running
temperatures - so what if the fans don't turn on until the current "set" temp.
Since the car is at idle, I'm not too concerned about engine wear at idle
speeds (and at factory settings) - the main idea would be to make the engine
run cooler at speeds - wouldn't a simple stat change provide that??
I also assume we're talking about reprogramming with something like one of
those Hyper-Tech Power Programmers or some such. I wonder if a private
vette shop would have the ability to re-program...? Think a dealer would do
it (car is out of warranty)?
Almost makes me yearn for the belt-driven fan... nahh!! :crazy:
Old Mar 8, 2002 | 11:30 AM
linkschamp's Avatar
linkschamp
Just got off the phone with a local (and I think great) Chevy dealer.
They informed me that they have a "replacement" stat (180 deg) that
costs $22.32 (Plus $115 installed). However, after checking with their
"resident certified vette machanic", I was told the fans come on automatically
at 218 degress and CANNOT be reporgrammed!!
I would be REAL curious if anyone has changed their termostat and had
any success (or need) to reprogram the fan(s)... :chevy
Old Mar 8, 2002 | 11:58 AM
Mark Leiter's Avatar
Mark Leiter
the fans come on automatically at 218 degress
Its been a while since i read the shop manual for my '95 but i think it said that the aux cooling fans came on at 228d not 218
Old Mar 8, 2002 | 01:39 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: Running cooler (Mark Leiter)
I went with the switch so I can turn the fans on while in the pits.
Old Mar 8, 2002 | 01:53 PM
dtorc4's Avatar
dtorc4
The dealer is trying to take you for a ride, Links. Everything can be reprogrammed. How else would Hypertech, Ed Wright, Jet, etc. make any money? I have found that most dealer mechanics I talk to know very little about modifications to vehicles. Maybe this is just because of my area, but they want to make as much money from you as they can. Order a chip or programmer (I'm not completely familiar w/ LT-1 computers) and get the fan to come on at a lower temp. :cheers:
Old Mar 8, 2002 | 01:58 PM
vader86's Avatar
vader86
OK, heres what you have to do. On your year, you need a chip. DONT buy the Hypertech chip as it does nothing for way too much $$.
Get the 160 tstat, clean off the front of your radiator (it will have dirt and debris in there, causing your car to run hotter) then you will need a chip burned to make the fans come on earlier. My stock fan comes on at 225 and my auxiliary fan (in front of the radiator) comes on another 10 later or somthing like that.
The manual switch is a good thing, but once you get on the road it really doesnt do you any good, its better to keep your car cool when its idling. You dont want the fan to be on all the time you know.
Go to the ECM section and look up Marcho Polo and see if he or someone else here with the right equipment will burn you a chip for less than the hypercrap chip, if you have some major mods, then id recommend Ed Wright at Fastchip.com.
Old Mar 8, 2002 | 02:46 PM
Kale's Avatar
Kale
Default Re: Running cooler (vader86)
A thermostat swap is one of the easiest jobs you can do, definately do it yourself.
Old Mar 8, 2002 | 03:10 PM
BaseballDude's Avatar
BaseballDude
Default Re: Running cooler (dtorc4)
I recently added an Ed Wright Chip (10 minute install) and 160 degree thermostat (about a 20-30 minute install.....I took my time between beer sips). And I can honestly tell you that I should have done this when I bought the car nearly 3 years ago. She runs sooooooo much cooler now, and the WOT reprogramming is much, much better.
Old Mar 8, 2002 | 03:13 PM
linkschamp's Avatar
linkschamp
Hhhmmmm... interesting, boiling point of anit-freeze solution is 227d - I think
that's cutting it a bit close!! :eek:
Old Mar 8, 2002 | 03:46 PM
linkschamp's Avatar
linkschamp
The Chevy dealer that I was referring to actually told me to buy the part
and install it myself... that it was that easy and there was no need to have
them do it - I've changed these things so often when I was younger that
I'm sure its a no-brainer. I really didn't want to get into "mucking" with the
ECM/brain. Getting a chip burned might be a good alternative - have to do
some more checking. Maybe there are some kind of aftermarket fan solution.
You guys on the forum are great - only hope some day I can offer something
to this forum besides questions!! :seeya
Old Mar 8, 2002 | 06:26 PM
linkschamp's Avatar
linkschamp
Follow up after a little research...
This looks like an "automatic" fix for running the fans with a lower-temp stat
available from Corvette Central:
#244455 - $31.95 ea.
85-89 with B4P, 90-95 All.
Low temperature electric cooling fan switch and harness electronically kicks your fan(s) on at 200 degrees and off at 185 degrees. This not only cools down most hot running cars, but keeps the temperature in best performance operating range. Simply remove existing fan switch ( on cars with auxiliary fan) or the port plug (on single fan cars) and install low temp fan switch. The 84-89 with the auxilliary fan requires the harness. The conversion harness is required for installation on all 90-95 Corvettes.
To determine whether your Corvette has an auxiliary fan your vehicle option list will have "B4P" as an RPO code, fan is located in front of the radiator, as well as behind it, and an auxiliary fan relay is mounted at the top of the radiator fan shroud.
Couldn't seem to paste a pic here - but its basically the installation of a
new plug sensor - sure sounds simple... :smash:
To Running cooler
