Replacement Options for PKE Keyless Entry?
Old Feb 21, 2010 | 08:06 PM
C8H18's Avatar
C8H18
Default Replacement Options for PKE Keyless Entry?
I've got the original PKE fob for my '96. It works GREAT. But the plastic shell is falling apart after years of use. There are two significant cracks in the shell and the plastic portion that forms a hole for a keychain to go thru is broken off. Essentially it is now a fob that I carry separately from the keychain in my pocket.
I believe these can only be found on the 2nd hand market today.
Q: Anybody have any options specifically for repairing/replacing the 'shell'?
Old Feb 21, 2010 | 09:12 PM
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
I just went up under the SEARCH dropdown and put in PKE. Got a whole list of members selling fobs and fixing them. Try that.
Old Feb 21, 2010 | 09:15 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Here ya go.
http://forums.corvetteforum.com/c4-g...available.html
Old Feb 22, 2010 | 12:34 PM
C8H18's Avatar
C8H18
Thanks RollaMo-LT4 - that is an interesting thread. I sent the email addy a message - we'll see.
Last time I searched all I found for "PKE" was a ton of threads about how to program them, problems with programming etc and some used ones for sale here and there. None of which helps me.
Mine works great. The case or shell is showing it's age. Any used replacement will incur the cost of buying a 'complete' unit and will likely have same/similar age related issues. Heck a forum member got ripped off right here buying a 'used' keyfob just for the shell which turned out to be no good.
In a pinch - Black zip ties work well on the case. But I don't trust gluing the key chain loop back on - so just carry mine separate in my pocket.
Other possible solutions...
One might be able to slip a fat enough piece of shrink tubing over a portion of the keyfob.
I've seen some colored 'covers' for the C4 fob. They may just be for the front surface though...? Possibly could be glued on to cover cracks and create a 'new' loop hole for the keychain. About $15 or so.
I don't have any better ideas for fixing the loops once cracked/broken - plastic welding perhaps but it would likely turn increasingly into a 'Frankenstein' remote.
I briefly googled to see if the OEM (LECTRON PRODUCTS INC) may have made other cases for other automakers that might be dimensionally same/similar but nothing obvious jumped out. Besides they would likely be used/aged as well...
Obviously the ideal solution would be to obtain some brand new shells and pop the guts into it. That other thread gives me hope but didn't sound like there were any at present.
Old Feb 22, 2010 | 12:40 PM
markKlein's Avatar
markKlein
Somebody just posted a week or two ago about rebuilding the loop on the case. He had pictures and everything. Check this out
http://forums.corvetteforum.com/c4-g...fob-stuff.html
Old Feb 23, 2010 | 03:32 PM
pcolt94's Avatar
pcolt94
As said in the previous post the loop can be fixed. But if the case is passed epoxy repair, a new case might be needed. I have seen complete cases on Ebay and not too expensive. There not always there, you got to keep checking to see when they surface.
It always seems like there not there when you need them.
Might check the after market suppliers.
Old Feb 23, 2010 | 06:02 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Send Bree an E-Mail to see if she has gotten the cases in:
Please contact me for details at this email only
c4fob@yahoo.com
Best Regards,
Bree
Old Feb 24, 2010 | 10:29 PM
vettenova's Avatar
vettenova
My fob is all cracked too!
Old Feb 25, 2010 | 03:24 PM
markKlein's Avatar
markKlein
Not true, you can buy all the new ones you want for about ($130). Look at eBay or GMpartsdirect.
To Replacement Options for PKE Keyless Entry?
