Wanna buy a Code Reader..........
Old Feb 22, 2010 | 09:54 PM
MikeIz 82VETTE's Avatar
MikeIz 82VETTE
Default Wanna buy a Code Reader..........
hey guys gonna invest in one but which one? i saw 3 different ones at autozone. it there a particular one that everyone likes? autozone had them priced from 60bucks to 200bucks.
Old Feb 22, 2010 | 10:05 PM
Jon Hekking's Avatar
Jon Hekking
I like the ET50 from MAC Tool, about $70. Simple and easy to use.
A shameless self promotion
• Reading trouble codes – reads DTCs of powertrain system including CAN, both pending and current DTCs.
• Clearing trouble codes – clears both pending and current DTCs.
• Readiness test – status of each monitoring system about I/M.
• Displays VIN.
• Includes OBDII generic mfg spec DTC CD and manual.
Price: $69.99 (USD)
Old Feb 22, 2010 | 10:07 PM
Harsh20's Avatar
Harsh20
Is this for a '82 vette? do they have a computer? just asking
You will need one that is OBD1.
the the ones at the auto joints are OBD II only. the combo OBD I and OBD II are really expensive. 299.00 and up unless you find one with connectors missing (and it is always the one you need)
Old Feb 22, 2010 | 10:09 PM
Jon Hekking
I assumed it was for a C4, what are you using it for?
Old Feb 22, 2010 | 10:10 PM
pologreen1's Avatar
pologreen1
What year? I bought a $25 one about 13 years ago, for most Chevy computers.
Old Feb 22, 2010 | 10:15 PM
MikeIz 82VETTE
my 96 CE
my bad.
Old Feb 22, 2010 | 10:35 PM
mnstrlt1's Avatar
mnstrlt1
96' OBD-II
the Older c4's are OBD-I, in which case I haven't seen a scan tool for (nor have I really looked)>
*edit*
BTW- Autozone will scan the car for you for FREE... I don't see a reason to invest in one, unless of course you just want the tool for the sake of having it.
Old Feb 22, 2010 | 10:42 PM
cwyates4's Avatar
cwyates4
Originally Posted by mnstrlt1
96' OBD-II
*edit*
Old Feb 22, 2010 | 11:00 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
you need an obdII scanner, and the one I got was $200, but works with every car. Who knows what kind of car I may buy next? doesn't matter, I have a scanner for it.
Old Feb 22, 2010 | 11:03 PM
Jon Hekking
In that case;
ET97
• CAN Enabled Tool (No adapters to buy)
• Global OBD II (Domestic, Asian, European)
• OBD II Generic DTCs
• DTC Definitions
• Flash Upgradable
• State OBC Check
• Manufacturer Specific DTCs
• Generic Data Stream
• Graph Data Stream
• Graphic LCD
Price: $139.99 (USD)
Old Feb 22, 2010 | 11:41 PM
pjinca's Avatar
pjinca
Jon - What do you recommend for a 94? Thanks
Old Feb 22, 2010 | 11:42 PM
MikeIz 82VETTE
thanks guys!
Old Feb 23, 2010 | 12:24 AM
Sweet 90's Avatar
Sweet 90
Hey I know someone who works for Mac Tools. I should check with him to see if there are any deep discounts for CF members
Jim
Old Feb 23, 2010 | 08:01 AM
runner140*'s Avatar
runner140*
I purchased one from Harbor Freight a few years ago for $39.95
Used it quite a few times.
Old Feb 23, 2010 | 08:50 AM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
Actron Pocket Scan, ~$60.00 at Advance Auto Parts/ Auto Zone, etc.
Reads and erases ODBII codes.
Pays for itself after 1st use (if you consider most shops charge a minimu 30 minute scan charge alone).
Old Feb 23, 2010 | 10:08 AM
RLG's Avatar
RLG
I have one for OBD II but all it does is read codes and has the ability to clear them.
I have one that reads OBD I and that is all it does.
If you are serious about one, I have been looking for a Tech I,It was used by GM dealers and is bi-directional and obsolete.
reading codes is great , but sometimes it is necessary to activate the part in order to diagnose the problem
Old Feb 23, 2010 | 08:47 PM
Wathen1955's Avatar
Wathen1955
I've been thinking about getting a scanner, but I would like one that not only reads codes, but allows me to tweak some settings, in particular, the temperature at which the fans come on. I have a 96 also, and would like to change the default setting from ~225°F to 215°F for the first fan, and 225°F for the second fan.
What would be a good tool to use, or would it be better to take it to a shop to make the adjustments?
Old Feb 24, 2010 | 05:57 PM
MikeIz 82VETTE
To Wanna buy a Code Reader..........
