Weather strip grease/conditioner application
Old Mar 11, 2002 | 04:22 AM
mxw128's Avatar
mxw128
Default Weather strip grease/conditioner application
I just bought some of the weather strip conditioner from ecklers (I got the cheaper stuff) and was wondering what's the best way to apply it? Do I just rub it on and leave it sit? Should I give it a wipe after I apply it? Won't it smear on the windows and hatch when they are opened/closed??
Thanks!!
Mike
Old Mar 11, 2002 | 10:31 AM
Stv50's Avatar
Stv50
Default Re: Weather strip grease/conditioner application (mxw128)
Are there any directions? My first thought would be to apply and wipe off the excess.
Old Mar 11, 2002 | 11:21 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Weather strip grease/conditioner application (Stv50)
No, what you have to do is spread it real thin. Don't glop it on. Take a small dab and work it in to the rubber. Any excess, keep spreading it, but if you apply it thin enough, you won't have any excess to wipe off.
Old Mar 11, 2002 | 01:04 PM
carter200's Avatar
carter200
Default Re: Weather strip grease/conditioner application (Mr Mojo)
Yea, what he said :yesnod: :seeya
Old Mar 11, 2002 | 01:35 PM
Square's Avatar
Square
Default Re: Weather strip grease/conditioner application (carter200)
I second Mojo's recommendations. :seeya
Old Mar 11, 2002 | 04:56 PM
carter200's Avatar
carter200
Default Re: Weather strip grease/conditioner application (Square)
You can't second cause I already did before you :p:
Old Mar 11, 2002 | 11:07 PM
ittlfly's Avatar
ittlfly
I heard that it is the same as diaelectric grease.... and you can use that on the weatherstripping instead of the high dollar stuff. Is that correct?
Old Mar 12, 2002 | 01:17 AM
mxw128's Avatar
mxw128
Thanks for everybody's help...I'll soon have better protected weatherstrips! About how often do you guys reapply this stuff?
Old Mar 12, 2002 | 02:24 AM
merrick's Avatar
merrick
Default Re: Weather strip grease/conditioner application (ittlfly)
I heard that it is the same as dielectric grease.... and you can use that on the weatherstripping instead of the high dollar stuff. Is that correct?
Yes,thats right. It's a silicone lube. I like to lube up the seals on a warm day in the sun and let it soak the rubber for 24hrs. Then wipe the excess.
Old Mar 12, 2002 | 09:54 AM
Square's Avatar
Square
I would let your fingers tell you. After you apply it the first time you should be able to feel the silicones presence for quite a while (weeks or months). When the rubber feels dry again, then it is time to revisit it with the grease. You don't want the weatherstrip to feel wet, you want it to feel new.
Sorry Carter200, I third Mojo's recommendations :jester
[Modified by Square, 7:55 AM 3/12/2002]
[Modified by Square, 7:56 AM 3/12/2002]
Old Mar 12, 2002 | 08:47 PM
carter200's Avatar
carter200
[QUOTE]I would let your fingers tell you. After you apply it the first time you should be able to feel the silicones presence for quite a while (weeks or months). When the rubber feels dry again, then it is time to revisit it with the grease. You don't want the weatherstrip to feel wet, you want it to feel new.
That's cool SQUARE I was just funnin you :cheers:
To Weather strip grease/conditioner application
