C4 Bose help
Old Mar 16, 2010 | 05:13 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Default C4 Bose help
Was splicing a wire and inadvertently touched a live wire to the case of the radio. Now I get no sound and the antenna doesn't move. Fuses in the panel didn't blow. Radio was tested and is fine
Old Mar 16, 2010 | 05:43 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
"Radio was tested" before, or after the arc?
Old Mar 16, 2010 | 06:04 PM
Cruisinfanatic
I'm using another radio that is known to be working
Old Mar 16, 2010 | 06:09 PM
Sheri'sCherry87's Avatar
Sheri'sCherry87
did u test ur connections?
Old Mar 16, 2010 | 06:13 PM
Cruisinfanatic
I put back in the same radio I took out an hr before. And now ant doesn't move and no sound
Old Mar 16, 2010 | 06:16 PM
lexman52's Avatar
lexman52
Does the radio have it's on inline fuse.
Old Mar 16, 2010 | 06:21 PM
Cruisinfanatic
the problem is not the radio.
Old Mar 16, 2010 | 06:28 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
Maybe "arc" fried CDM?
Old Mar 16, 2010 | 06:30 PM
Cruisinfanatic
whats that?
Old Mar 16, 2010 | 07:01 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
whats that?
My understanding is it's the real brains of the stereo but I am no expert.
Old Mar 16, 2010 | 07:04 PM
Cruisinfanatic
looks like that's for a 90 up.
I have an 85
Old Mar 16, 2010 | 07:09 PM
Sheri'sCherry87
u might find an answer here:
http://forums.corvetteforum.com/audio-electronics-20/
Old Mar 16, 2010 | 07:11 PM
Sheri'sCherry87
wups.. i see u posted there already.. nm
Old Mar 16, 2010 | 07:12 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
I have an 85
I just pulled some CDM photos off ebay because after checking your profile I could not find a pic specific to your 85.
These all list as 90+ but are somewhat different...
You might want to post in the audio section
Good luck!
Old Mar 16, 2010 | 10:02 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
There are no inline fuses, the Radio fuse and the CLK/CTSY fuse are both required for the system to work.
Did you put a meter or test light on those fuses, or was it a visual test ?
Old Mar 17, 2010 | 03:14 PM
Cruisinfanatic
Finally found the problem. Knew as soon as I opened the door this morning and no lights. DA!!!!
Who would have thought that the clock/ctsy fuse powers amps, antenna, locks, interior lights, and good knows what else.
Thanks to all that gave me advice
Old Mar 17, 2010 | 04:54 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
Back on the road!
To C4 Bose help
