Should radiator stop leak be added to a 1990 via the outlet up on passenger side by the window, or via the radiator overflow? I guess same question could be asked of the antifreeze?
When i fill at the outlet up top it runs low, yet i have plenty in my overflow. Am i doing something wrong?
That sounds funny if its low in the radiator it should take it from the overflow?
Maybe the seal is bad on the radiator cap?
Or on the over flow! mine was bad on my over flow and i was loseing antifreeze and coulden't figure out where it was going till i got some teflon tape and put it in threads and fixed it!
From: Southside of Western Norte Americano State of Confusion, ColoFornia
St. Jude '13
Radiator stop leak isnt a sin... Its just not the best approach to the problem.. If the car leaks, Fix the leak.
Stop leak varies form brand to brand and I have used it several times on the farm equipment and other items where you just have to keep it going a few days (like during harvest).
Its just a band aid at best and it will leak again sooner or later.
You would want to add it at the pressurized tank by the passenger window. This is also where you would add antifreeze if you were changing it.
The white tank down by the passenger side headlight is the unpressurized overflow. This means it sees very little coolant flow, it only gets a little extra coolant when the engine is hot, and returns a little coolant as the engine cools down after shutoff.
Yeah but then you get the guy with the pin hole in the freeze plug above the cross member and has driven 8k miles without any problems.
And you also have this guy here that drove a car with a pinhole leak and fixed it and drove without problems. Till one day, the radiator came apart and he was in the middle of BFE. At that point make sure you listen for the weird kid in coveralls playing the banjo.
Why band aid a thing like that? Why not just fix it and have peace of mind?
It is a bandaid, but sometimes you got to wonder. I used it in a POS Blazer beater and it fixed all the leaks. Yeah it looks pretty nasty afterward. But I found that one it blocked it, it seemed to stay sealed even after changing the fluid. Maybe luck (for once). For all I know that thing is still going thru the mud pits somewhere!
No, I would not use it for a radiator cap leak. Replace the cap with an OEM of the same pressure.
The only time I would think about using it in the Vette would be for the dreaded heater core. That thing just give me the ******* and if mine ever leaked I might dump the car to tell you the truth. I have a real phobia with Part #1. That aside, I would be tempted to bypass it first. With it bypassed, I might be tempted to try to find someone to replace it for less than $1,000
