finally figured it out!!!!!!!!!!
Old Apr 11, 2010 | 08:25 PM
wvonwaldner's Avatar
wvonwaldner
Default finally figured it out!!!!!!!!!!
ok so ive been trying to figure out why my coolant system was overpressurizing and leaking thru the waterpump weep hole and over heating...after all my best efforts i replaced a ((5)) dollar radiator cap..now it drains out into the overflow jug and on a hot day never seems to rise in temp above 219...wooohoooooooooooo..after all this i replaced plugs, wires, air idle control valve, throttle position sensor, coolant temp sensor and compressor...this c4 now drives like a kid in a candy store..FAST FAST FAST
Old Apr 11, 2010 | 09:00 PM
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
That sense of accomplishment always feels good.
Old Apr 11, 2010 | 09:37 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Old Apr 11, 2010 | 09:58 PM
socalman's Avatar
socalman
St. Jude Donor '10
I don't want to bum you out, but the 'weep' hole you are talking about is not a 'weep' hole. It's a sign water pumps give you that they are done. Also leaking on your Opti (depending on year). The cap may fix the overheating, but the pump needs to be replaced as it will always leak.
Old Apr 11, 2010 | 10:21 PM
wvonwaldner
pump is new...
Old Apr 11, 2010 | 10:53 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
Originally Posted by wvonwaldner
pump is new...
Newly rebuilt? Leaking out of weep hole...time for a new one.
Old Apr 11, 2010 | 11:30 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
It may only leak when over-pressurized. If it doesn't leak with the new cap and the temps are normal, should be good to go.
Old Apr 12, 2010 | 06:43 AM
78pacer's Avatar
78pacer
The water pump should not drip from the weep hole...period. As the OP said, that pump is done. The coolant is bypassing the pump seal.
Mike
Old Apr 12, 2010 | 07:29 PM
wvonwaldner
Mike
well guys thks allot for responses...however the pump is new and still has new shine to it..doesnt leak at all anymore..no changing it unless i see signs of anymore leakage.
Old Apr 12, 2010 | 09:56 PM
RedVette84's Avatar
RedVette84
To finally figured it out!!!!!!!!!!
