Spark plug install Question
Old Apr 15, 2010 | 04:48 PM
Hondo48's Avatar
Hondo48
Default Spark plug install Question
Is it necessary to coat the plug tip with a di-electric silicon before reattaching the plug wire? If so, how much?
Old Apr 15, 2010 | 05:07 PM
torchred89's Avatar
torchred89
I put just a tiny bit around the boot so they don't stick if you have take them off again. But you don't have to
Old Apr 15, 2010 | 05:22 PM
pologreen1's Avatar
pologreen1
Never had a problem with that.
Old Apr 16, 2010 | 09:27 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
I put a tiny bit also. If youv`e ever torn the plug wire out of the boot because the boot was "welded" to the plug you`ll see why its worth it. (sometimes you just cannot get those boot removal tools on the boot)
To Spark plug install Question
