radio problems 1986
Old Apr 17, 2010 | 12:42 PM
walleyedan2's Avatar
walleyedan2
8th Gear
Default radio problems 1986
when i pulled car out of storage i'm getting no sound from the radio.it's a bose system. tuner ant. allworks. just no sound. iwas told to check the amp relay, but i can't get the bump out piece on the dash out any help out there would be great thanks.
Old Apr 17, 2010 | 01:00 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
the relay is not in back of the bump. I think it's in back of the center dash
Old Apr 17, 2010 | 01:27 PM
walleyedan2
8th Gear
do you think the no sound would be the amp relay
Old Apr 17, 2010 | 01:43 PM
Cruisinfanatic
Could be the relay,
also, do the floor lights on you car work when you open the door. If not, that's your problem. Courtesy light fuse
Old Apr 17, 2010 | 01:52 PM
walleyedan2
8th Gear
passenger side does not work but ifigured that it was just a bulb. are they tied in with the radio and why?
Old Apr 17, 2010 | 02:00 PM
Cruisinfanatic
ask the guy that designed it. Check the fuse (courtesy)
Old Apr 17, 2010 | 02:12 PM
walleyedan2
8th Gear
fuses where all good, and the amp relay is not right behind the radio. i think i might give up for today and go fishing, thats a no brainer, and more relaxing. any other idea's would be appreciated, thanks for the help.
Old Apr 17, 2010 | 04:42 PM
megtom2's Avatar
megtom2
Remove the lower hush panel on the passenger side. Lay down with your butt in the seat, your feet sticking over the headrest and your head in the floor. On the right side is where the relay will be. If it is the original it will still be attached and if not it will be dangling down. Replace the relay and all should be well.
Old Apr 17, 2010 | 04:48 PM
Cruisinfanatic
never said it was behind the radio
Bose relay check
Old Apr 19, 2010 | 08:49 AM
walleyedan2
8th Gear
just want to thank everyone for the input on my stereo problem, every little bit helps. just to let you know it was the relay. vary hard to get at though. it was located up and to the right of the info panel. had to take the bumpout out and the ductwork to get at it.again thaks for the help.
Old Apr 19, 2010 | 08:59 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If you could see through the dash, the relay is just below the bottom left corner of the crash pad. It's mounted to the left side of dash support brace and attached with two 7mm hex screws.
You may just want to reach up through the wiring and unplug relay, pull connector down and plug in a new one. The wire colors to connector are pink, orange, black and pink/black stripe.
Old Mar 18, 2018 | 12:24 AM
Mark A. Thomas's Avatar
Mark A. Thomas
7th Gear
Default Relay 😑
I have an 86. I changed the rrlay and still nothing. Any more ideas ?
Old Mar 18, 2018 | 07:35 AM
Cruisinfanatic
When was last time it worked?
What does it do, not do?
The courtesy fuse is good? You need to swap it with a known working one.
Old Mar 21, 2018 | 11:41 AM
Izzy Dizzy's Avatar
Izzy Dizzy
relay location. You can access it from underneath. Pull off right lower cover and prepare to work upside down, but you can get to it. I suggest pulling the plug off and bring the wire harness down and plug in a new relay.
To radio problems 1986
