"While I'm under there"
Old Apr 23, 2010 | 05:47 AM
galt1074's Avatar
galt1074
Default "While I'm under there"
Okay fellas, I just got my FSM so now I feel like I kind of belong. They've also kind of given me delusions of my own mechanical grandeur and I created a list of things to do. If anyone has suggestions for things to add or remove from the list, fire away!
1. Find/Fix oil lead (stupid and vague I know but I've got a tiny oil leak either coming from the pan, the drain plug, filter, or oil temp sensor.
2. Replace ign control wire (the purple wire running from the solenoid to the ign relay has a short somewhere that keeps it from cranking sometimes)
3. Plugs and wires
4. Drain and flush coolant
5. replace oil and filter
6. check Rear Diff fluid
7. Check Tranny fluid
8. replace cooling system hoses
9. clean suspension, underbody, and engine
10. change backup light switch on tranny
I know this thread is going in this direction but trust me, I don't have the time or the money to completely rebuild the car...just want to get some MUCH overdue maintenance done and clean her up a little.
Old Apr 23, 2010 | 07:13 AM
Leec4ce's Avatar
Leec4ce
11. Check brake fluid if dark and nasty Change brake fluid
12. Replace Power Steering Fluid
Drive car and have fun
Old Apr 23, 2010 | 08:44 AM
Churchkey's Avatar
Churchkey
Lube ball joints & tie rod ends.
Check all the u-joints for play, if they have grease fittings lube them.
Check control arm, batwing & dog bone rubber bushings for splitting, deterioration, oil soaking.
Check the c beam mounting bolts
Old Apr 23, 2010 | 11:54 AM
Jamesnns's Avatar
Jamesnns
As long as ur at it.
Chng Fuel injectors
Chng O2 sensors
Clean TB and IAC
chng air, fuel filters
I'd take a look at ur Oil pressure sending unit
Old Apr 23, 2010 | 12:21 PM
Frizlefrak's Avatar
Frizlefrak
So whatcha waitin' for muh brutha? Break out the toolbox and get to wrenchin'
And if you get in over your head, stop and ask us. We'll part the seas and make everything right again. It's what we do.
There's nothing on the car you can't do if you follow the manual, take it slowly and methodically, and use some common sense. But do change the brake fluid....hardly anyone does this, and I'm betting it looks like molasses.
Old Apr 23, 2010 | 01:21 PM
jimmymack's Avatar
jimmymack
St. Jude Donor '09 thru '25
and the fuel filter as mentioned
Old Apr 23, 2010 | 04:30 PM
Pwnage1337's Avatar
Pwnage1337
13. Abuse until satisfied
Old Apr 23, 2010 | 07:13 PM
pologreen1's Avatar
pologreen1
or until you have to climb under it again
Old Apr 23, 2010 | 07:49 PM
SQUIRMIN VERMIN 84's Avatar
SQUIRMIN VERMIN 84
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
And the knuckle-busting begins.....actually, blood is a cool color!
Old Apr 24, 2010 | 01:10 AM
HlhnEast's Avatar
HlhnEast
Check the Intorcoptor fluid..................Oh wait, is it a seven speed???
Sorry Galt man, just still snickering over the last post I read about a CraigsList ad
Watch that "while I am in there" it can run ya some money.
Old Apr 24, 2010 | 01:26 AM
yaknow's Avatar
yaknow
check and/or replace serpintine belt
Old Apr 24, 2010 | 01:43 AM
Frizlefrak's Avatar
Frizlefrak
Correct. Only on the 7 speed with Turbo Port Injection.
Old Apr 24, 2010 | 04:46 AM
galt1074's Avatar
galt1074
Default Thanks for the suggestions
Everyone, thanks for the ideas. I'll probably take care of a lot of these that I haven't gotten to already. I've done brakes so they should last until I upgrade, serpentine is done, and I keep the chasis lubed with most oil changes, fuel filter was done about a year ago, and I've been shopping for front and rear suspension rebuild kits so I'll probably save a lot of that for some time a little down the road.
On the comment about injectors...I'm not sure it will get done now but it will probably happen soon. My question would be, are there upgrades or do I replace with OEM?
I actually do have the seven speed, six forward and one backward so I probably should check that interceptor fluid because reverse isn't giving me the speed I need, and I'll contact that guy on Craigslist about upgrading my injectors to turbo.
One more reason to be very careful about your online dealings.
To "While I'm under there"
